90 - 94 polo bits
Items left
Row Item
1 Full GT/G40 body kit comprising of 4 arches and 2 sill trims VGC £50
5 GT/G40 boot carpet good condition £15
7 Standard boot carpet good condition £10
9 AAU/AAV metal breather pod VGC £8
10 G40 Charger belts good few miles left in them £3 (£17 each + vat from VW).
11 Uber rare diesil/GT large plastic/rubber radiator air duct surround with the GT air intake built in £10
12 Standard polo radiator air duct rubber/plastic surround £8
13 Standard Grill VGC all clips in tact £8
15 GT/G40 Header tank with water level sensor £5
18 OEM Factory Sump guard mounting bracket passengers side £3
20 GT/G40 Steering Damper and bracket £25
21 Uber rare obsolite fabric rear parcel shelf and 4 mounting brackets (grey checkered pattern) £25
24 Haynes manual 90 - 94 models £5
25 MK2 coil and rubber jonny cover £8
26 VW dealers road maps £1
27 VW polo Drivers handbook £3
28 VW mk2f/mk3 release brochure rare late 1990 £15
30 Rubber trim that goes along the rear edge of the bonnet to stop fumes entering the cabin fan £2
31 Retro petrol can SM and BP 1960s item in red and white with brass top £10
32 VW Van showroom brochure £5
36 Coil conversion kit amp and coil and wiring diagram £15
39 Clear glass unetched Quarterlights with rubber £10 each
40 Clear glass unetched door window glass £10 each
41 Clear Glass unetched rear passengers side Coupe £10
43 Factory green tinted (etched) side window glass £15 each
44 Factory green tinted (etched) rear side windows Coupe/saloon) £15 each
46 Clear glass unetched front windscreen £20
47 Factory sliding sunroofs in calypso green, black L041 £20 each
48 GT/G40 Black infill panel for above £10
49 GT/G40 rear load sensor valve bracket and spring got both early and late body shapes £20
50 complete wiper motor linkage and motor £8
51 Dash blanks £1 each got all 3 shapes
54 "GT" Grill badge and boot badge "Polo GT"£20
56 Rear saloon VOLKSWAGEN badge £1
57 Corrado spoiler/sunroof switch and connector with bit of wire £1
58 Rear coupe badge £1
59 Grey GT Squareback door card set £20
61 Black parcel shelf £20
65 Standard polo wheel trims x 3 VGC ( 1 new) £12
66 GT heck wheel trims x3 £10
67 5 speed gear linkage complete £15
70 Fuel lines flow and return £10
71 AAU/AAV fuel engine bay wiring loom £15
73 GSF fuel tank 1 year old was fitted but the car never went anywhere so like new £40
76 Steering Rack done 67K £15
77 Rear engine mount and bracket the bolts to the Gearbox £10
78 Drivers side engine mount on chassis leg complete £10
80 Genuine VW mk3 Radiator £22
81 G40 front brake carriers £10
83 MK2 golf rear callipers (rusty but can be refurbed or used as exchange items £5
85 Spi Disi £10
86 SPI TB £12
87 SPI ECU £10
88 SPI inline pump £15
93 VW type 1 brakes, disks pads, callipers carriers £15
95 Mk2 polo Headlamp washer pump £10
96 Passat rear door lock cover ( new in the box) doesn’t fit mk3 polos £1
97 5 speed ARB £5
98 Speedo Cable £8
99 Accelerator cable £8
100 Clutch cable VW auto adjust one £8
101 Seat belts £5 each
102 Gloss black powder coated bolt on water pipe (non GT/G40) £12
103 Gloss black powder coated brace that bolts to the floor after the CAT £10
104 Track day camera used twice, maked good little videos just needs a micro SD card, inc box instructions cd etc £15
105 Pair of car ramps (blue) £15
106 Snooper speed trap and danger spot thingy boxed with receipt etc £30
107 Audi presentation polish tin and cloth with model range CD and brochure inside £3
108 Driver side Drive shaft cover (metal bit that bolts to the block £1
109 Squareback rear tail gate in alpine white done 31K (its mint) with clear unetched glass £35
110 Boot lock with Key £6 posted
115 Coupe rear wiper motor complete with jet etc £10
116 Early Grey GT interior seats with rear bench £50
118 VW logoed rocker cover with retaining nuts etc £5
119 steering column surround top and bottom bit sits infront of the clocks where the hazzard button pops through the middle all clips ok £10.
120 Enzo cup wheels set of 5. 14" et38 pct 100 (standard vw polo fitment) 3 new in the box 2 had a tyre fitted but still very good. cost £65 each new so open to decent offers considering 3 are still brand new.
123 Wee JML dermal kit almost new in box with all the bits £5.
124 OEM uncut Dashboard front Speaker wiring loom £4
125 OEM uncut handbrake cable loom £1
126 OEM uncut rear polo loom dash to back lights pumps etc. £20
127 OEM uncut Centre consol wiring loom with cigi and also the without version
128 OEM Coupe tailgate wiring loom 1x 4 pin connector chopped off but you have to do that to get it off anyway. £5
130 NZ ignition Coil brand new in the box £30
132 Standard rear brake backplates pair VGC £10
132 Servo complete £15
133 Brand new front bumper in the VW padded bag, never seen the sun or a car! £80
136 GT/G40 optional Extra leather steering wheel with the silver trim £65 posted
Edited by genesisGT
  • Replies 55
  • Views 2.7k
i know it doesnt mention it in the above but i dont suppose you have a front g40 grill badge???
sorry keeping spare G40 one i have. can get one on german ebay new for about £25. :thumbsup:
Have you hired a Transit van for the show this year Richy... :shock::lol::lol:
can i have a number 55 and 92 and some prawn crackers
Now that's a list! Don't see it, but worth asking - do you have an NZ/GT/G40 waterpipe with the ISV bracket on?
u got pics of 3,11,16,92,102,103 cheerz dan
yes, do you want sauce?
cheys03 - staright up answer is no but the powdercoated one would do the job but the ISV would need "X" cable tied on.
dan
OEM+ Door latch covers - pics of the same items are in my saloon thread in the photo section if you do a quick search and pics of the powder coated bits too. heres the thread pics of the covers on page 2 clicky
Uber rare diesil/GT large plastic/rubber radiator air duct surround with the GT air intake built in £15 pic below. basically its for the big bastard 525mm rad not the uk standard 420mm one fits all except G40 pics below and its safely removed.
Ged brace bar front £15 see andys dubstyle section think he has a pic there. basically goes from ARB mount on driver side to chassis leg on passengers stiffening up the front end.
92 - gone guy 2 above you bought them
101/102 - look liek standard items but lovely gloss black see the same thread as the door covers.
lol its a bit like bingo now.
Edited by genesisGT
I'll take the GED bar please Richard?
It may be worth taking a deposit if you're bringing all these parts down as there are a lot of timewasters here as you know!
PM'd
sorry to jump in, i have a g40 one spare - they have a bolt on water pipe though generally. (most gts have push fit)
PM'd :retard:
Hello
Would you post the centre consol to SA9 1GS? If so I will take it.
Grant
Hello
Grant
yeah postage would likely be about £5-6 due to size rather than weight though in bubble wrap with black bag over the top.
PMs replied to.
Edited by genesisGT
ok martin will dig it out for u.
will be taking full money from people i dont know but you nick, ross etc who i know not really an issue.
can do photos of most items too if desperate.
P&P is fine PM'ed for payment details.
ill take item number 34 posted please mate!
cheers
Ross
hello mate
No-118 vw logoed rocker cover, is this the silver one that can be polished up? i'll have it if it is cheers
I'll take the genesis rear seats please dude?
Thanks for the offer of waterpipe - unfortunately need a push-on one with ISV mount. Cheers anyway.
hello mate
sorry its just the bogo standard mk3 one but vw did a gay one with no logo so its more for replacing that . mk2 and 4 ones polish up better.
g40ross - pmed you the postage price (£11) if you are ok with that there yours.
cheys03 - no worries! not seen a push on pipe one actually so interesting to know!
BrettG40 - ok if you pm me we can sort it out.
grant.morrison - pmed you back mate.
pm sent about several items
tom your items on its way 1st class.
Grant & Peter your items will be posted tomorrow
new items added.
PMs replied too.
prices are not set in stone so open to a bit of negosiations especially if posted. rarer items less movement available.
afraid the money up front 1/2 on small bits full on large/heavy/dirty bits i need to enforce as its a 673mile round trip for them if i dont
Edited by genesisGT
I will take number 129 and all 3 switches, could you pm me the total cost?
pms replied to and more stuff added.
Edited by genesisGT
