90 - 94 polo bits
Got the console today, just what I was after. Many thanks.
  • Replies 55
  • Views 2.7k
ah good stuff.
Danny and Karmann your switches will be posted tomorrow morning .
PMed
Hi Richard
Wondering if you have a front 5 speed gearbox mount to sell?
Grant
hi Grant sorry i dont. i have the rubber bit but not the metal surround.
No worries, thank you for looking.
bump
list updated and items sold
missing numbers = binned or sold
Row Item
1 Full GT/G40 body kit comprising of 4 arches and 2 sill trims VGC £50
5 GT/G40 boot carpet good condition £15
7 Standard boot carpet good condition £10
9 AAU/AAV metal breather pod VGC £8
10 G40 Charger belts good few miles left in them £3 (£17 each + vat from VW).
11 Uber rare diesil/GT large plastic/rubber radiator air duct surround with the GT air intake built in £10
12 Standard polo radiator air duct rubber/plastic surround £8
13 Standard Grill VGC all clips in tact £8
14 Cabin fan, rad and plastic casing etc and squeek free motor!!! £10
15 GT/G40 Header tank with water level sensor £5
17 GT/G40 Black sunvisors £8
18 OEM Factory Sump guard mounting bracket passengers side £3
20 GT/G40 Steering Damper and bracket £25
21 Uber rare obsolite fabric rear parcel shelf and 4 mounting brackets (grey checkered pattern) £25
24 Haynes manual 90 - 94 models £8
25 MK2 coil and rubber jonny cover £8
26 VW dealers road maps £1
27 VW polo Drivers handbook £3
28 VW mk2f/mk3 release brochure rare late 1990 £15
30 Rubber trim that goes along the rear edge of the bonnet to stop fumes entering the cabin fan £2
31 Retro petrol can SM and BP 1960s item in red and white with brass top £10
32 VW Van showroom brochure £5
33 Wing mirrors 1/2 primed in tornado red wee bit of peal at base but u don’t see it when fitted £10 pair
35 drivers wing mirror has a new glass glued on top but hardly noticible cable adjust version £8
36 Coil conversion kit amp and coil and wiring diagram £15
38 Clear glass unetched rear side for squareback £10 each
39 Clear glass unetched Quarterlights with rubber £10 each
40 Clear glass unetched door window glass £10 each
41 Clear Glass unetched rear passengers side Coupe £10
43 Factory green tinted (etched) side window glass £15 each
44 Factory green tinted (etched) rear side windows Coupe/saloon) £15 each
46 Clear glass front windscreen £20
47 Factory sliding sunroofs in tornado red, calypso green, black L041 £20 each - 1 sold to Chris
48 GT/G40 Black infill panel for above £10
49 GT/G40 rear load sensor valve bracket and spring got both early and late body shapes £20
50 complete wiper motor linkage and motor £8
51 Dash blanks £1 each got all 3 shapes
54 "GT" Grill badge and boot badge "Polo GT"£30
56 Rear saloon VOLKSWAGEN badge £1
57 Corrado spoiler/sunroof switch and connector with bit of wire £1
58 Rear coupe badge £1
59 Grey GT Squareback door card set £20 or offers
61 Black parcel shelf £20
62 Coupe parcel shelf side supports (obsolite from VW) clips ok but 1 wee speeker clip snapped off £15
64 Standard polo wheel trims x4 £4 each or £10 the set.
65 Standard polo wheel trims x 3 VGC ( 1 new) £12
66 GT heck wheel trims x3 £10
67 5 speed gear linkage complete £15
70 Fuel lines flow and return £10
71 AAU/AAV fuel engine bay wiring loom £15
72 Front bumper (Standard) few wee marks but nothing serious off my saloon £10
73 GSF fuel tank 1 year old was fitted but the car never went anywhere so like new £4076 Steering Rack done 67K £15
77 Rear engine mount and bracket the bolts to the Gearbox £10
78 Drivers side engine mount on chassis leg complete £10
79 Front lower radiator panel £15
80 Genuine VW mk3 Radiator £22
81 G40 front brake carriers £10
83 MK2 golf rear callipers (rusty but can be refurbed or used as exchange items £5
84 Mocal 10 row 235 wide cooler dented on one side but holds pressure 1/2bsp male fittings £4
85 Spi Disi £10
86 SPI TB £12
87 SPI ECU £10
88 SPI inline pump £15
91 Fan cover ( tool tray) £8
93 VW type 1 brakes, disks pads, callipers carriers £15
94 Pair of bare front struts £20
95 Mk2 polo Headlamp washer pump £10
96 Passat rear door lock cover ( new in the box) doesn’t fit mk3 polos £1
97 5 speed ARB £5
98 Speedo Cable £8
99 Accelerator cable £10
100 Clutch cable VW auto adjust one £8
101 Seat belts £5 each
102 Gloss black powder coated bolt on water pipe (non GT/G40) £12
103 Gloss black powder coated Cat brace pipe £10
104 Track day camera used twice, maked good little videos just needs a micro SD card, inc box instructions cd etc £15
105 Pair of car ramps (blue) £15
106 Snooper speed trap and danger spot thingy boxed with receipt etc £30
107 Audi presentation polish tin and cloth with model range CD and brochure inside £5
108 Driver side Drive shaft cover £1
109 Squareback rear tail gate in alpine white done 31K (its mint) with clear unetched glass £30
110 Boot lock with Key £4
112 Petrol cap with 2 Keys £8
115 Coupe rear wiper motor complete with jet etc £10
116 Early Grey GT interior seats with rear bench £50
118 VW logoed rocker cover with retaining nuts etc £5
119 steering column surround top and bottom bit sits infront of the clocks where the hazzard button pops through the middle all clips ok £10.
120 Enzo cup wheels set of 5. 14" et38 pct 100 (standard vw polo fitment) 3 new in the box 2 had a tyre fitted but still very good. cost £65 each new so open to decent offers considering 3 are still brand new.
121 MK4 interior light black factory tinted £1 with section of wire
123 Wee JML dermal kit almost new in box with all the bits £5.
124 OEM uncut Dashboard front Speaker wiring loom £4
125 OEM uncut handbrake cable loom £1
126 OEM uncut rear polo loom dash to back lights pumps etc. £20
127 OEM uncut Centre consol wiring loom with cigi and also the without version
128 OEM Coupe tailgate wiring loom 1x 4 pin connector chopped off but you have to do that to get it off anyway. £5
130 NZ ignition Coil brand new in the box £30
131 Standard horn with connector £1
132 Standard rear brake backplates pair VGC £10
132 Servo complete £15
133 Brand new front bumper in the VW padded bag, never seen the sun or a car! £80
134 Samco (blue) charger to intercooler hose used but still ok £10
135 90s Rocco Twin horns far more manly than the polos road rage defusing meep. £10
136 GT/G40 optional Extra leather steering wheel with the silver trim £65 posted
137 Almost new K&N filter for all SPI polos £20 boxed
138 Squareback Rear lights pair with bulb holders £20
139 HELLA clear front indicators with LED side light conversion with loom and chromed bulbed indicators, plug and play £24
140 Bosch electric life (OEM VW) electric window motors and linkage upright bolts straight in. motor sits lower than standard polo kits but all its needs is a metal plate with 4 drill holes in it, + electric window instructions and wiring diagram £50
out of the seats obviously i can only bring 1 set as my polos not a 7.5 tonner!
probubally more to but that’s the stuff I'm tripping over most
Prefer collection at the polo show if your willing to pay most of it in advance, can post most of the smaller stuff if your willing to cover the postage and wrapping materials.
SOLD Collect at show.
45 Factory green tinted (etched) front screen £20Chris
8 GT/G40 Injector jackets obsolite from VW I believe £24Chris
2 OEM headlamp protectors with instructions almost new from the group buy I did 2 years ago £70 Chris
3 OEM+ Door latch covers £15 Chris
133 GSF Armour door plates (pair) fit under the door handle £8Chris
117 Early Black GT interior seats with rarer 50/50 rear bench £60 Nick collection at polo show
55 OEM Rear polo mudflaps need a good scrub and brackets left in diesil for a few days £10Ross collection soon
34 Wing mirrors pair cable adjust VGC £20 Chris
92 New stickers for the above £4Ross collect soon
37 First aid kit ( black) fits in the VW holder complete with german contents etc £10Chris
4 GT/G40 boot carpet average condition £10Chris
missing numbers: sold or binned.
heres some pics:
hi rich what rim width are the enzos please also do you have the boxes and how much would it cost to post to al3 7nx if poss
how much for the rocco twin horns posted to PO6 4QR?
cheers
cheers
hi mate £14 posted as they are nice and light and will fit in a wee box.
ANybody got a GT in-line fuel pump for sale?
sorry dude not got one of them.
open to offers on any of it collected at the polo show
Sorry to be a pain Rich but could you post pics of items 15,43,44,84,133 ;) you know I'm as anal as you :)
Edited by quiksilver_jake
hi jake
yeah i have 2 of no 15 two are bit yellow original VW ones one has bit more brown shit at the bottom than the other
rear qharter glass is the original vw stuff with a H plate reg in the bottom corner on them
84 i cant find :oops:
133 imagine a bumper thats black wishout all the rain lines, sagging and fadedness and your there.
will see waht i can do photo wise after work tomorrow as i leave for the polo show thu morning with the gang.
list updated
Edited by genesisGT
Hi
I'll take the boot lock and key please!
Oh, and does the radiator have the fan, or do you just have a fan (with motor) ?
Chris
Edited by chrisfunk
Chrisfunk:
yeah will bring it with me mate just pm me your phone number and what day you will be about. I'm there thu night - sun lunch time.
radiator doesnt have a fan but i have a single speed fan if thats any use. the twin speed one has sold.
regards richard
Sorry - Not had a chance to read your list.
But I'm interested in the rocker cover...and do you have a pair of Mk2 radiator top mounting brackets?
How much posted please.
rocker covers not a problem could do it £14 posted in a big jiffy bag.
not got any mk2 specific bits really, sorry.
Hi Richard
Do you still have 14 the cabin fan and is 86 the SPI TB for a 1 litre or 1.3? If its for a 1.3 could you PM me a posted price for both, if not just a price for the fan
Cheers Grant
have these been sold? - 93 VW type 1 brakes, disks pads, callipers carriers £15?
if not how much posted?
cheers, miles.
hi mate sorry the type 1 brakes got binned a few weeks back
grant sure the one i have is a 1.0L throttle body but yeah the fans still available postage would be £8.50 on it in a box as its quite fragile plastic
Just the cabin fan then please :-) , is your paypal the same? Let me know and I will gift it tonight.
Grant
yeah all still the same. might have to wait till after the polo show to post it though as I'm at work all day tomorrow then leave at 8am on thu.
Can i have the horns please ill be at the show to collect
Set up your own little trade stand Rich, you have enough to sell lol!
