Mikuni carbs and custom inlet manifold with Mk2 ignition
After much fiddling i had my carbs running sweet yesterday but i have been offered a company car and now the car is going back to standard injection and being passed down the family so this is up for grabs,
Comes with regulator but no pump cost me £300 + P+P literally a week ago, no pump included but everythin else there to get it running sweet, sound amazing.
Anyway offers around £270 + P+P (should be about £20 due to weight Recorded and insured.)
These have already been jetted and suited to the AFH block and just need to be adjusted according to fuel air ratio etc.
Easy. Peasy.
36845_409971094197_700029197_4300883_302
36765_409970774197_700029197_4300881_755
Edited by Boss
  • Replies 25
  • Views 929
Ok had a thought about it and would like the cash to buy some new Roadie wheels, £270 delivered :)
what carbs are they mate.. and what pump would be needed ?
cheers
Just a facet low PSI pump £20-£30 new, R1 carbs :)
Sounded the nuts tis a shame really but i'm sure my sister doesn't want loud carbs on her car haha.
would you mind splitting up the setup as i am in desperate need of an inlet manifold for my cbr600 carbs, so long as the spacing is the same or close enough to work...
If i can get rid of the carbs at the same time then sure, it's custom made and port matched, high quality. So yeah if someone wants to take the carbs??
BUMP!
BUMP!
i am strugling with understanding my carb conversion atm mainly due to the bickering on this forum (they should ban users that post rubish on the technical forum) so i ask you willur your r1 set fit my 86c mk3 1.3 polo mate if so ill take it no messin arround.
Haha, yeah i know what you mean, you would need anothe inlet manifold, as mine is designed for a AFH 1.4 16V and is port matched but the carbs will go on no problem..
can you just split them please :) i need the inlet :)
Yeah, ok say £150 posted?? Very good quality can upload you pics if needs be... port matched and very high quality.
£150? i have been offered a new one for £105...
come on you can do better than that :)
also pictures would be good yes
craig
Edited by pugownerbilco
36370_413551079197_700029197_4377938_297
35289_413550914197_700029197_4377926_585
If you have been offered one for £105 then go for it. I will go to £140 posted but thats it, same price as the group buy.
BUMP!
BUMP! NEED RID OF THEM! £250 posted.
BUMP!
is this plug and play there or there abouts ?
what will need doing to get these badboys set up on a 62 gti ? :)
What roadie wheels you after?
If i remember correctly the 6n2 ports are the same so they are just plug an play. All you need is a facet fuel pump, or use the t-peice method :)
I have no idea yet, probably some fulcrum racing 1's Ritchey WCS suck arse :(
fail. the ignition setup wont work on the 6n2 gti unless you drill the cam to accept the dizzy, or use aftermarket ignition management
Cleared that up then. nope.
Edited by Boss
how much if i pic them up
You pick them up this week, you can have them for £250 cars gone now so no need for them...
ill have them for £225.00 posted.
i can pay by paypal tomorrow.
pm me if your interested
regards, chris...
I'll give you £250 posted for these...if I can get exact deatils of the required pump and where to get one from too :)
