track rod end mk2
:cry::cry: can somebody please help i wewnt to change my drivers side track rod end and it seems to be crimped on. how do i change it and is the rack bent to be bent like it is. please help thanks steven
  • Views 4.3k
you have to change the whole arm I'm afraid, the rod end isn't removable.
oh dear where can i buy one from? been on gsf
422VG0010 TRACK CONTROL ARM PO (Not G40) 10/78 >7/94 £18.50
430VG0030 STEERING RACK-RHD(NEW) PO >7/94 £58.45
will i need the whole rack ?
no, just the arm. There's a nut and bolt in the middle to remove it from the rack.
thanks for help dude
hey man hope u get this in time thats not the part you need from gsf the parts you put is basically the wishbone arm. I just replaced both my steering arms and track control arms the part you actually need is
435VG0210 TIE ROD-RH BQ PO (Not G40) 8/82 >7/94 29.50
Thats the drivers side steering arm that will fit your car hope you get this in time mate and its meant to be bent for the ackermann sindrome something to do with when you put it on full lock its turns one wheel slightly more than the other to make the turning circle tighter and smaller.
Hope this all helps and good luck mate its an easy job.
:D
Peter
