how to remove the steering wheel from 6n2
as title
been stuckling for awhile
  • Views 1.2k
remove allen keys in back of wheel to disable airbag first, then pull centre out and there will be a 24mm nut, undo that and hey presto!!
sorry, thought you had a 6n, same as but without allen keys!!
theres a technique to it.
Theres 3 spring clips you need a small screwdriver for. at the back of the steering wheel, these unclip the airbag. There a right pain.
When thats off theres a big nut in middle and 3 i think torx bits that hold the horn wiring on. Undo these and remove if you dont you'll end up in a big mess!
Then the big bolt. Slide wheel off the spline.
The worst bit is them clips, cant really describe how its done just have to play with it! I got one side out then stuck my fingers in the gap to stop it from falling back in when you try to attempt the other side.
aw thanks for the info guys i shall try tomorrow and see how i get on
wheel is off now cheers for the help
nice one, well done! i know how tricky they are!
