Interior advice.
just deciding what to do with my car interior and thinking about re-trimming my seats, door cards and dash board. just a few questions to start with for now;
-how do i remove the front and rear seats ?
-how do i remove the door cards ?
-how do i remove the dash board ?
-what is the best way to retrim the door cards and dash ?
any other advice is very welcome and appreciated.
thanks
Mat
  • Replies 8
  • Views 1.5k
what mk u got just strip my mk 3
and i would never remove the dash one asssy job to do and get back in
I've got a mk4 1996 1.4 8v cl I've seen a leather dash and deads and door cards all done before and i thought it looks rather good jsut wasnt my taste in colour
any help please
Get you self a Haynes manual.. should answer all your questions and many more..
Except for how to re-trim them.
yeah I've got one but i was thinking peopke might have first had experiance
You'll need alot of high temp spray adhesive, trimfix is the best I've found, which is heat resistant up to 70 degrees. normal spray adhesive wont cut it, it'll sag and lift after about 2 days, especially in warm weather. Doorcards clip on round the edges, theres 2 screws under the door pull, you'll need to unscrew the door pin, then just pull and they should come off. rear cards are secured with a little screw at the bottom, 2 caps behind the seats, and a swift pull and they'll come off. dash is a whole different ball game, theres about a million screws and its fairly hard to do.
on the trimming side of things, you need alot of patience, alot of material, alot of time, and either a sewing machine, or the way i do it of making cuts in the parts rather than stitched joins, and alot of practice!
seats are quite hard aswell, the way i found was to take the covers off, split the covers so there in there individual pannels, glue these face down onto the back of the new material, cut round it and re-stitch! but unless you have a sewing machine that will handle it, a large ammount of time and a few spare interior parts i really would either save up for it doing or get some that have already been done, as its not an easy job!
thanxs for the advice I'm lucky really becasue I've got my brother who can do all the re-trim as he ust to do it for a living and is very good, thakn you for the advice on how to get everything off the car for starters
any more advice is welcome
