Guide: How To Install OEM Remote Central Locking In A Polo 9N With Original Parts
4 minutes ago, Pete1 said:
Do you have a photo of the suffix E Convenience module you fitted? (part number label specifically). Seem to remember there are some bits after the main part number that may need to match old-to-new?
I forgot to take a pic, its a bit dark here now but I can get a picture tomorrow. Did you mean the H02/S0002?
My previous H model was H02/S0002 this and so was the the E version I bought
  • Replies 250
  • Views 107.5k
  • cunning plan
    cunning plan
    First of all, thank you for taking time to write this up, very useful and helpful. However, I think there is some confusion between simply adding Remote Central Locking using your existing transpond
  • Yes, you can indeed recode the unit to a 5/3 door quite easily with VAG-COM/VCDS.
  • Thanks man, appreciate it. Ordered a CCM with key with a pre-programmed transponder, should be a plug and play so looking forward to it
35 minutes ago, Pete1 said:
OK, I thought that must've been what you did, but didn't want to assume.
I forget the details now, but it sounds like what you did probably ought to have worked, so it may be an issue with an over-cheap fob.
I bought an allegedly genuine one after a failed attempt with a cheapo one initially, and that was only about £15 from memory. Luckily, the bit with the electronics and the bit that I'd already transferred the immo chip into were not the same half, so I could make a hybrid fob out of the cheapo immo/key section and genuine 'tronics.
But all that was before I realised that the door had to be locked using the key rather than the buttons on the fob, so it may be that the cheapo fob would've worked, never went back to try it.
After a bit of thought about this I would say it's probably a high chance of the cheapo fob. What I am now going to try is putting the transponder from Key C back into Key A where it originally came from.
I will try and start the car, if the immobilizer doesn't let me start the car then I guess, this would mean the transponder chip was damaged in the process of being taken out when I initially transferred it into key C? (it doesn't look like it has been damaged though on visual inspection)
Any how I will report back my findings.
Edited by Skolzey
Good morning guys,
I have great news, I went to try the above and as I was unscrewing the remote fob to get out my original transponder, I accidentally hit the remote lock button and I heard the doors lock! I can confirm this is now working!!
One thought I have had about this was maybe the casing was screwed too tightly on the remote fob, perhaps a signal couldn’t quite get through? I am not 100% sure however.
I have also called up an auto lock smith local to me and will hopefully be getting the blank blade on the flip remote cut tonight.
I will report back later to let you know if it works starting the car with the immobiliser! But judging from everyone else this shouldn’t be a problem.
Edited by Skolzey
Yes, exactly.
☺️ Great stuff.
Makes you want to dance around with your hands in the air, doesn't it?!  😁
3 hours ago, Pete1 said:
Yes, exactly.
☺️ Great stuff.
yes yes! I am so happy with it! I went to sleep last night with the biggest headache going over all the potential things it could be, and just couldn’t believe it when it unlocked this morning, it’s made my day! 😄
Hi Guys,
Just had the remote flip key cut, can confirm it is unlocking the doors manually with the flip blade and starting the car! All done and working, it's been a journey. Thank you to everyone who has contributed to this over the years. 🙂 I will keep an eye on this thread and try to help out anyone in future!
Skolzey
Gents,
Installing this to a 9N3 couple of questions (i have attempted to fit the Rclick thing but dont work)
The CCU part number is the same for 9N3?
Can I use the flip blade keys that came with the Rclicks kit?
On 04/05/2021 at 12:17, patters1978 said:
Gents,
Sorry for late reply, it needs to end with E and be the H02/S0002 variant
Rclick flip blade should work, mine was purchased from rclick seller on ebay "VW Remote Control 3-button 434Mhz: 1J0 959 753 AH"
hope this helps
  • 4 months later...
Okay someone please help. I know its a old thread but i like to keep things in one place.
I own a 2003 Polo. LHD, im from Slovenia. Is it possible that the car doesnt have any kind of central locking or is it more likely that its broken? I have to unlock every door individually. To unlock the back door i have to unlock the front and reach behind.
I want to setup remote locking so my wife will stop going nuts and I'm not sure how many parts I need and if it even worth it then. If i need to replace the locking mechanism in each door or even run wires all around the car that makes it very unlikely that I'll try this.
First Welcome to the forum.
It is quite possible that you have a basic spec where the locking was only by the drivers door lock, so it is quite possible that your drivers door lock mechanism has failed ( common problem with the internal micro switches) so it's not signalling the other locks to lock/unlock
To continue this question, please make out a new posting in this "ICE/Electrical" rather than clog up this FAQ
good afternoon, my 9n3 pole from 2003 has this 6Q0 959 433 G H02/S0002 ECU and I bought one 6Q0 959 433 E H02/S0002 but when I put it in the car after having inserted the soft code it doesn't work with the command even after programming in the port. and after opening the car, if you don't put the key in the ignition, the four turn signals are flashing. the keys I bought were these 1JO 959 753 DA can someone help me?
  • 3 months later...
Anyboody can Help me?
  • 2 years later...
My Polo 9N has the 6Q0 959 433 E and the car's remote locking works, but I don't have the function to raise and lower the windows remotely (holding down the lock or unlock button), just putting the key in the lock, I saw that the 9n3 has this function, can I exchange the comfort module for one from the 9n3? Here in Brazil, it is rare to have a Polo without remote locking,
I don't think this is accurate information.
Here in Brazil, all 9n3s have this function
Strange, because I don't think any in Europe do; the CAN-based window motors in 9N are more likely to be able to do this than the LIN-based ones in 9N3.
What window motor part numbers does your car have?
Edit, I see that in the Brazilian market the change to the LIN-based ones didn't happen.
In Europe, late 9Ns and all 9N3s I believe have LIN-comms between the window motors, and those have no comms with anything central, so I don't think they can do anything via the remote signals.
This doesn't help you at all; sorry.
Edited by Pete1
Did I understand, what would LIN be? I had seen in several posts from Europe that holding the key in the lock in the lock or unlock position would raise or lower the windows, doesn't that work?
I've also seen a module called KVW100 that promises to activate this function via OBD2, but it's unfeasible to bring it to Brazil and using VCDS my central doesn't have the option to activate it like it does in the Golf, well, I'm a bit lost, especially since the comfort module code is the same in Brazil from 2003 to 2014 (the new Polo only came from 2015 for us) which makes it difficult to know which has the function and which doesn't
27 minutes ago, albonico said:
doesn't that work?
Yes, that does. That's an input directly into the window motor(s) from the lock(s), rather than a signal from something central like the CCU.
LIN is a cheaper, simpler version of communication network compared with CAN, LIN Bus Explained - A Simple Intro [2023] – CSS Electronics
You don't need to worry about that though, because your car is all CAN.
  • 6 months later...
Hello,
Im not sure if i’ll get a response anytime soon but i’ve just tried to locate my ccm which i managed to do so but i have absolutely no idea how to get it out any help would be appreciated as i’ve got a new one on the way this is on a uk polo 9n 2004 i can see it goes out by pushing it upwards but it just seems to start hitting a bunch of cables and cannot get out and i’m struggling with this as id have an awful time fitting the new one in if i managed to get it out
Edited by charlie17
  • 7 months later...
Sorry for bumping an old thread, but I would like some guidance.
After locating and checking the CCM unit, I found I have a 6Q0 959 433 H, H02/S0002 on my 9N3, which I was told was compatible with remote locking by someone online who had done the switch, however as I researched more, I can only see people using the E variant. Has anyone tried this with a H variant CCM? or would I be better with getting a E variant?
H is what you find in cars with central locking via key in door lock only. It doesn't contain the necessary components for remote C/L.
Needs to be the suffix E part.
Edited by Pete1
Thanks for the quick responce! Would this E Vairant be suitable? Its h02/s0002 like my current H CCM.
Ebay Listing
Edited by Keyvoo
I believe so, yes.
Thanks for your help! I ordered the part, hopefully it will all be working soon.
Update: I got the new Ibiza CCM installed and my door module fixed. I linked my key today and its all working. Couldn't be happier.
