Guide: How To Install OEM Remote Central Locking In A Polo 9N With Original Parts
Just wanted to add incase it has not been mentioned on the thread, you can purchase a 1J0 959 753 AG Fob (the two button lock/unlock variant) and it will work with the 6Q0 959 433 E CCM.
In order to synchronise/pair the fob to the CCM I had to use the manual teaching method (note I have not yet had the blade cut so used 2 existing keys for this method, you do not need to have a cut blade for the fob in order to manually pair the remote fob):
  • Use an existing working key to turn the ignition to the on position
  • Roll the window down (not sure if this is necessary or more precautionary incase something goes wrong to ensure you can get back into the vehicle)
  • exit the car, close the door
  • With the car still on (key in ignition turned to electrics on) place a second key into the door lock (can use the new fob if the blade has been cut)
  • Twist the key in the door to lock and unlock the car
  • Then press any button on the new fob
  • You should hear an click from the car
  • The fob is now paired and if you remove the key from the ignition and close the door, then press a button on the fob it should work
I did also try using VCDS to adapt the AG fob to the car, it did make a click sound for the existing AD fob and the new AG fob, but only the AD (3 button) fob worked, the AG (2 button) fob did not do anything when I pressed to lock/unlock. VCDS also showed only 1 stored remote after doing this procedure, so make sure to use the manual teaching method instead for the AG fob. My assumption is that the VCDS diagnostic key adaptation is very particular about which fob model it will allow to be stored in memory, whereas the manual teaching method is more lenient. (Note that after doing the manual method to successfully pair the AG fob to the car, VCDS still showed only 1 stored remote, however both the AD fob I purchased initially, and the AG fob are both working perfectly to lock and unlock the car)
(Incase anyone is wondering, the reason I got the 2 button AG fob after initially purchasing and using the 3 button AD is that I preferred having 2 large lock/unlock buttons as I never used the boot unlock feature)
  • Replies 250
  • Views 107.5k
  • cunning plan
    cunning plan
    First of all, thank you for taking time to write this up, very useful and helpful. However, I think there is some confusion between simply adding Remote Central Locking using your existing transpond
  • Yes, you can indeed recode the unit to a 5/3 door quite easily with VAG-COM/VCDS.
  • Thanks man, appreciate it. Ordered a CCM with key with a pre-programmed transponder, should be a plug and play so looking forward to it
