Mk3 Fuel Leak
Hi, I have a Mk3 polo and it leaks quite alot of petrol when you throw it round corners. Its coming from around the filler cap i think however I couldnt see exactly where it was leaking, i had a good look around the filler neck on the inside of the arch and checked all the pipes but still couldnt see anything. The petrol is on the body just below the filler flap and it also runs down the inside of the arch from the top of the filler neck.
Anyone else had this problem?
Could it be coming out of the tank from the filler cap, it just seems unlikely as it would mean the petrol would have to travel all the way up the filler neck.
Any help appreciated!
Joe
  • Views 859
Take off the cap and see if you have a rubber seal on the cap. If this is missing or split then fuel will pour out of here on left hand corners!
GSF do new ones for like a fiver
I had the same problem as the rubber had gonr crappy on the original and it stuck of petrol everytime i got out of the car.
Ok i will try that then, thanks. I didnt think the fuel would be able to get that far up the filler neck haha.
Joe
