Polo with motorbike engine
Well I'm just wondering whether you know of any companies that do these eminent conversions.
Also for a 17 year old would the insurance for a polo with a gsxr bike engine be very high??
  • Replies 28
  • Views 11.6k
Erm...........probably!
I would be very surprised if you could find an insurer to cover you....
z cars do them for minis but would probably cost 10,000 at least
i doubt insurance would be high at all because i doubt you could find an insurance company stupid enough to insure a new driver in a highly modified bike engined hatchback. the cost of the conversion and running costs would be very expensive too and i very much doubt you could use it as a daily tbh.
you need to do the work , get the vehicle sva tested to show you are not a numpty with a spanner then insure it as a kit car :-D
Vee-dub is right you would need to do most of it yourself. easiest way it to mount the engine on its own frame inside the bay.
like this mk1 golf...
Have a look here:
Linky
or try Zcars
As for insurance IF anybody even thinks of taking you on then prepare to bend over and be raped on cost.
Edited by Cymro
Have a look here:
Linky
can you put a motorbike head on a vw block , i saw it somewhere think its with mk3s 1.3 for a type of motorsport
the easiest way would be to mount it in the back and using a chain drive on to a modified sprocket with a drive shaft connected either side of it drive each of the rear wheels.
not the best way but by far the easiest
vee-dub: i think there was something as it rings a bell but cant remember for were I read/heard it.
The one issue i hadnt though about was the pic above is in a mk1 golf, the heavy 6n frame might put too much strain on the engine/drivetrain.
mk1 golf is about 800kg standard (<taken from an online source so is most likely a lot less) and that engine has 350 bhp so thats about 444bhp/ton as the car is stripped then its could be 500+bhp
6n is around a ton so you lose about a hundred bhp instantly.
Mcloving: that would be most definably the easiest way, rear engine would mean bigger engine space. :)
Edited by Cymro
insurance for a 17 year old with a heavily modified car :lol: :lol: :lol:
Sorry.
I would have thought a 6n would be to heavy for it to be worth putting a bike engine in it. The only cars I have seen with bike engines are really light like mini's etc
Tbh mate it is a crazy idea for someone with not Much mechical skills and a 17 year old.
I spoke to Z-Cars a few years ago about making a frame to fit a Hayabusa engine into the back of my breadvan. They quoted £4000 just to make the frame!
Then you have to add on the price of an engine, rear axle, plus the million other things to make it all work. Not worth it IMO.
Then you would be wrong. Haven't seen the Dutch (I think), 6N with a bike engine in the back? Rapid as fook. 150-160bhp with a 15k redline is enough to make anything moderately sized move pretty quick, plus bike engines weight alot less than car engines, all they have to run is themselves, not PAS, ABS, Massive alternator etc.
Bike heads are possible on other engines though! you'll need a chain drive to drive the cams instead of belt drive, machine the block, and chop and change some bits, but it is possible.
Edited by deviance
plenty of bids on YouTube!
Hotlinks dont work ¬_¬
Anyway, do you have the gonads to cut your boot floor out? Bet you dont.
Also, your forgetting how impractical not having reverse is ;)
Edited by slyboogie
I wanted to put a GSXR engine in the front of an AX GT powering the front wheels (more to be different than anything ;) ). I had it all planned out and found sources for all the parts I would need, but I didnt have the time. Ended up putting it in a Seven chassis though, which is now finished and awaiting its first test session :D :
http://www.streetfire.net/video/team-sidew...vw-po_88740.htm
this looks pretty rude.
not sure about daily driving though like people have said, and i dont think insurance companies will touch you unless you maybe went specialist - plus you'd definately need to know your stuff if planning on doing it yourself.
You'd probably be able to get insurance by the time you finished the project assuming you're 17 now. It ain't gonna be a quick one.
This made me lol! To be fair if he had everything he needed and all the tools, it wouldnt take too long to finish.
You could always put a 1000c motobike engine in it, and not tell anyone, I mean hey, it would technically still be a 1litre ;)
I wouldnt recommend that though :lol:
Thats the one that ended up Orange.
this website maybe
http://www.clubpolo.com/
but why do you not just have this/every site you use on bookmarks though man? so much easier
Dodgy as.................
mate its a very nice thought but leave it in your mind till your about 25 then you,ll get insurance
