Will polo 6n2 1.4 8v gearbox fit polo 6n 1.4 8v ?
Will a gearbox from a polo 6n2 1.4 8v fit a polo 6n 1.4 8v ?????
Also this is probably a stupid question but where do i find my gearbox code.
Ben
  • Views 1.5k
Ben
If yours is a cable change box most likely, if rod change no, what year is your car? If its later than an R with mk4 golf style clocks and flat blade style keys then its prob cable change. We got stung trying to fit an earlier box to a cable change car theres no mounting flange for the cable mech. Make sure its a 6n2 8v too,
should do
the gearbox code is stamped on top of the engine side of the bell housing just under the dizzy :-)
Mine is a p reg yeah it is rod type gear linkage, so your saying it wont fit. yes it is a 1.4 8v
Ben
if its a rod is wont fit
you might be able to convert it to cable by taking out the rod assembly and replacing the whole gearstick assembly
with one from a polo with cable shift
Ok thanks buddy, any idea where to find the gerbox code ??
Ben
