Wet feet
me and my mate both have water getting in somewere and leeving puddles, cant find for the lif e of me where it is coming from i have taken all the sound proofing out and siloced all the rubber gromets on the floor and its still getting in, the seals are all fine, so I'm baffled. we both have 6ns
any help would be great
alex
  • Replies 12
  • Views 1.9k
Is there soapy stuff in the water? Could be rear washer fluid pipe!
nope its rain water because its every time it rains :cry:
same got it in my footwells in the front i took all the sound ending out and put some towls down to dry it out lol but mine looks like its comin from behind the dash probibly coming in where the scuttel pannel is (plastic bit under wind screen ) ...... but try pullin u carpit up in the front and puttin a running hose on the roof of you are car and sit in side and see were it coming from ??? i think this could poss be a common problem with the 6n it mabe be that people cant tell that water is coming i cos of the carpit and mats .. all this water in my footwell pisses me off too :crybaby:
yer i put towels down but still piss wet through, and with the raaint at the moment am just gunna take 1 of the popppers outa the floor to drain it self and fix it when its sunny :) mine has that much in after 1 day of dryness that its puddled throgh the carpet and the mats :crybaby: i will give the hose pipe ago mate when its a fine day cheers
yer i put towels down but still piss wet through, and with the raaint at the moment am just gunna take 1 of the popppers outa the floor to drain it self and fix it when its sunny mine has that much in after 1 day of dryness that its puddled throgh the carpet and the mats i will give the hose pipe ago mate when its a fine day cheers
by the sounds of it you are leaks quite alot compared to mine :? but anyways good luck :)
Check the membrane behind the door card, my 6n had a leak from condensation/rain seeping through the membrane on the driver's side and the footwell kept getting soaked when it rained. Also quite hard to notice as it can drip down in just one corner of the door.
Of course also check all of the main door seals with a hosepipe as well ;)
also this should probs be in hte technical section
Edited by Narrow_Lane
time for a cathater?
i had two leaks in my 6n polo. first was where the metal had corroded under the pollen filter, it was full with leaves and stuff in that tray water couldn't drain away.
second came from heater matrix leaked out behind glovebox, where the electric connection sits into the heater ducting. changed the matrix and now my polo no longer condensates everyday.
hope this helps
have pics of first leak if needed
hope this helps
yer stick some pics up ill like too see i think mine may be the heater matrix :S
sit inside and get someone with a hosepipe to put water all over it. Mine had a leak at the bottom of the rubber where it joins and it used to trickle in.
Have you got a sunroof???
thanks 4 all the help i really think its the heater matrix because a had a water fall from behide the glove box the over day when i set off :(
nope i dont like them :lol:
