Window rubber seals
Hi,
the window rubbers that run along the bottom of the drivers door window have completely disintegrated and need replacing. I've had a look around on the internet and asked in a few local shops but cant find anything that looks similar.
Does anbody know where sells new seals?
They don't need to be vehicle specific as long as they do a job?
  • Views 1.7k
Are the mk3/2f seals not available? As the doors are the same
fairly sure you will still be able to get them from vw, i can get you a part number of etka if you want it??
VW still do them apprently, about £22 each when i asked about 3 weeks ago
£22 is a bit steep for a bit of rubber!
Shouldn't be surprised though.
Is there no other place that sells lengths per metre?
Search car building solutions in google. They specialise in kit cars and have loads of stuff. May have what you're after. Failing that, scrappy
