6n2 EGR Warning light, please help
I have a warning light on, the problem was diagnosed as insufficient flow through the EGR valve. The valve and all surrounding pipes have been cleanes as they were all fairly shitty. However, the warning light is still on, does this mean the problem is still there or does it need taking to VW to reset before the light will go off?
Also will driving with a faulty EGR valve (if it is still faulty) do any serious damage to the engine before it gets repaired?
Please help me :)
Thanking you (on a 6n2 1.4 16v)
Edited by DubVirgin
  • Replies 9
  • Views 8.9k
No damage mate its just the exhaust recirc valve its there for emissions purposes so don't worry, if you have fixed the problem most faults reset after driving a few hundred miles.. That might be exaggerated but it varies depending on the problem..
Run it and see how you go should just randomly turn off one day..
Dimz
Its done about a 200mile trip since then and light still on. Least it wont have done any damage.
How hard is it to fit a new EGR valve?
(Thanks for the info, its usually much harder to get a straight answer on here lol)
The ecu just needs reset, its just telling you its stored a fault and to get it checked
Not very..let me have your engine code if you have it and ill see if i can upload the Volkswagen workshop manual for it..
Good point if you want to reset it quicker you could just pull the battery or the ECU fuse and leave it to reset lol..
Dimz
Edited by don_stavrou
This is for the AHW engine which is 75BHP:
This is for APE, AUA, AUB, AQQ which is 100BHP:
I think the engine code is AUB. Its a 6n2 1.4 16v but the 100bhp not the 75bhp. Is the engine code the first letters of the engine number on the v5?
All help is much appreciated :)
Thankyou :) which number is the EGR Valve?
Feel like a right noob lol
12 on the AUB image..
hope that helps
Dimz
I've just got mine unplugged, runs alot better and smoother oh and is more responsive and isnt clogging up the throttle body and intake manifold full of shit, I've had a new one on aswell but still having an error for it coming up. so its just unplugged, been like that for a year now
