1 day to bug jam please help
1996 6n 1.6glx
took the throttle body off and cleaned it right up but after returning it it is reving around 2-3000rpm and everything is plugged in exactly how it was. If i remove the sensor from the top of the body it revs go down to 900rpm but as soon as i put it back in it goes all the way up again.
does the throttle need to be reset or something on the vagcom or do i have to clean out the Idle control valve?
if it needs the vag does any one know a decent garage in the Watford,Hemel,St Albans area?
thanks
previous problem i was trying to solve
when i am in 2,3,4th and around 3000/4000rpm it jerks and power loss and have to play with the accelerator untill power comes back. I've had this problem for a while but its getting worse
i ran the VAG and i got
00519 -155 KWP1281
INTAKE MANIFOLD PRESSURE SENSOR (G71)
CLOSED THROTTLE
IDLE POSITION SWITCH(F60)
  • Views 1.2k
yep.
As for those fault codes, clear them, drive a for a bit and see if any re-appear.
yep.
great thanks mate!
1996 6n 1.6glx
thanks
It could well be that the throttle body needs to be re-aligned. Any half-decent garage should be able to do that for you
00519 -155 KWP1281
CLOSED THROTTLE
1996 6n 1.6glx
thanks
00519 -155 KWP1281
CLOSED THROTTLE
all sorted thanks
