Swapping mk2 bumpers for facelift?
Hi guys...
New to Polos and new to the forum.
Do the mk2 facelift bumpers fit the older mk2 bready?
Is it a simple swap?
Anybody done it or is it considered a no no...?
Cheers in advance.
Dave.
  • Views 696
not a simple swap no , it has been done though
not sure it looks very good
Fairly easy if you're happy with cutting and adding bits to plastic (plastic welding with a soldering iron works best with the bendy stuff the mk3 bumpers are made from). Start with mk3 bready bumpers so they're long enough behind the rear wheel, you'll need to drill some holes and bolt through the valances, and work out how to light the plate up.
The scene kiddies will hate you for it, but if you like it, that's what matters.
