'95 6n rattle from the front
I've had an annoying rattle recently and I've had a quick look today and It looks like the bottom bolt on the nearside caliper doesn't have a sleeve and if I tug the bottom of the caliper it makes a similar noise to when I'm driving, also it doesn't happen under breaking.
Where can I get my hands on a new set of bolts? I've looked at eurocarparts and gsf doesn't seem to have the right part, is this bolt called a brake caliper slide bolt?
Is there anywhere else I can try, don't really want to be buying 2nd hand stuff though.
  • Views 715
vw is the only place i know of
you could get away with a used one,down to you
