Door card removal
ah great, somthing else has bust!
Driver's electric window has stopped working, I think it may be the connector in the rubber thing in the door hinge.
How do I remove the door card folks?
(sorry its a 97)
r
  • Views 1.2k
Off the top of my head, I know its held on with some screws and then the usual door card popper things (cant remember the right name) if noone else replies by the time I get up, ill find the info in the haynes and photocopy it for you :) should get a haynes though - they are god!
Cheers matey
I have got a Haynes but didn't realise it would be in there Doh!
I shall have a look
No problem. If you cant find it let me know and ill take a quick peek since ill be needing to remove my door cards soon anyway since one is coming off and the other is grinding when i use the window :disgust:
you need to unscrew the door pin
remove the interior handle trim and beneath that there are 2 screws you need to undo
remove the electric wing mirror adjuster bit
then use a flat head screwdriver to prise the card away from the door panel, do not worry about adding force once you can get your fingers in, just pull it off and slip it round the door lever etc
beneath the door card there is a sound deadening thing that you will need to remove or cut away to gain access to the electric window...
hope this helps...it may also be the white runner clips if its stopped working, have just fixed mine =D
Thanks for the great help guys!
I've now fixed the window problem with some help of a mate of mine.
For those who may like the know the problem was in the large rubber wire gaitor that sits in the door hinge. When I removed it, quite a few wires had snapped! Not sure how this happened but that was the cause.
Russ
mine had this problem had a look electrical tape and conectors everywhere had to replace whole loon scrapyard job cost £2 for another one.
Edited by sev 101
