Painting a rusty rocker cover
Hi, as with most polos around my rocker cover is complely coated with a layer of rust.
I want to improve the look of my engine bay, would the best thing to do be to remove it, sand/wet n dry it down and then use a rattle can to spray it black? If so would it also be best to use heat resistant paint?
If I do do this, is there any major chance/risk of the open engine block or the inside of the rocker cover being contaminated with particles of dust etc?
Cheers for any advice guys!
  • Views 875
i used like a wire brush thing not sure when they called its a propper drill piese put it in the drill and that removed the rust , and just cover you engine up with a clean cover or something :)
would take it off 3x 10mm bolts put cling film over it then no shit gets in and keeps it moist.
then wire brush it or get it sandblasted then prime and paint it then put it back on.
Also, how is the rocker cover removed?
as above ^^ 3x10mm bolts through the top.. easy peasy to remove and put back on
