8v fog lights
hi all,
i've just got a 16 front bumper for my 8v polo mk4.
I'm wanting to get the fog lights to go with the bumper.
what do i need exactly to get the fog lights working?
where could i wire them up to?
thanks
  • Views 849
If you are lucky then the connections are there already, if not then you will either need to rip apart a loom from another polo with fogs and add the connections for the lights to the big connector on the right of the radiator.
Or do as I did and use a relay from the battery with bigger wires And they use the original wiring to operate the relay.
Hope this helps
8v fog lights will not fit 16v bumpers
