nakered gearbox just keeps going.
my box on my 6n2 started making strange noises around 80k and now has nearly 90k on and still keeps going, cant seem to blow it up :lol:
anybody else gone endless miles on a nakered box?
  • Replies 20
  • Views 1.7k
every other 6n2 owner lol
The noises it makes while driving along is proper bad, i find it unbelievable that it keeps going tbh :lol:
lol what noises is it making? sure its gearbox!?
yeah 100% gearbox and maybe release bearing on clutch.
it whines in 3rd 4th and 5th really bad, clutch makes crunching noises as you press and release it and whilst sat with engine running in neutral it makes strage clunking noises.
mine lasted about 10 miles when it went on strike,sounded terrible
sure there was someone in there with a chain saw cutting logs,people looked and sniggered as i went by,i just kept my chin up and headed to the mechanics :?
Edited by gaz2000
I've had the sort of ticking sound in my clutch (sounds like a loose bearing) since I've had the car (about 7000 miles) And mine whines in 5th.
How long have I got? Lol.
Fisher..
sure there someone in there with a chain saw cutting logs,people looked at sniggered as i went by,i just kept my chin up and headed to the mechanics :?
yeah thats a good way to describe what mine sounds like but its on and off doesn't make them noises all of the time just most of the time i just keep going on it still goes straight into all gears.
i had to force it into gear to get it to the mechanic,all the time knowing it sounded costly
I loved my gearbox whine, straight cut noise all day long was a joy to drive till i poked a hole through the bell housing lol..
Dimz
Dimz
i have interference on my stereo from the amplifier live cable
sounds like a touring car :lol: :p
Edited by gaz2000
I'm just gunna wait till it blows up tbh, ant got money to be gettin a new box at moment.
Given that mechanical failure accounts for some of the UK road network's fatality rates,its pretty irresponsible to drive a vehicle which is known as being at risk of a major mechanical failure.
The only time i ever had my drivetrain lock up,the differential allowed one front wheel to turn,locked the other,and that pulled the car to one side - into a bridge paraphet. The car was a write off,but nobody else was injured.
Lets hope its the same for you.
^^^ Ouch!
The gearfbox on the 6n has been making odd noises ever since it was purchased from the previous owner and its still going 30k miles later ;)
At the end of the day if you cant afford a new gearbox and need the car to get to work everyday then theres nothing i can do about it at the moment until i've saved up.
i bought my polol and the gear box wined in 5th gear all day everyday it had 99k on it it got to 117k and the gearbox decidies its going to give up makes a real bad clonking noise jus managed to get it home and lose all gears so put new one on and wighted in the old one everyones a winner
yes get as much use out of it as possible :thumbsup: lol
tbh I'm nearly saved up so will be dropping the nex box in in the next two weeks or so.
i had a diff lock up on me in a sierra twice in about a mile, once as i side stepped the clutch out of a junction on to the A5 for a split second (just enough to kick the back end out a bit more lol). then again as i got it side ways on the next island, i guided over a curb, across a grass verge parking it elegantly in the car park of a ford garage just as one of the blokes that worked there was getting out of his car. i just casually stepped out and said "do you mind if i park this here for 20 mins?", he just looked at me like 'wtf' while shaking his head, i thanked him and walked off to get a tow :lol:
:lol::lol:
My gearbox doesnt whine it just seems the gears are all over the place and first has a habit of dissapearing and making me go in to third. I have learned to drive it like it is though, it funny to watch my mates try to drive it they just cant find the gears.
well i did my box on friday on axle stand ad it took me 3 half hours to drop box and fit new clucth and put back together again then wieghted in gear box monday so everyones a winner lol
