wet carpets
hello all
My bast@rd polo is giving me grief!!!!!
The passenger carpet is soaked underneath the spongey insulation (you can squeeze it out). I can't find the laek at all. Any suggestions?
Does the floor pan have rubber grommets in that could have perished allowing water in? This happened in my boot :(
  • Views 882
hello all
Awww mate i have same problem but mine are puddles, and i have re silocend all the gromits and still coming in :(
common problem,
the drain holes under the skuttle pannel, just under the front windscreen get clogged up, then it overflows into the heater motor and into the passenger footwell.
It happened to my 6n, best advice i can give is strip the carpet, seats and remove a drain plug/ rubber gromit.
then remove all of the skuttle panel and stick a preassure washer down the drain holes.
You might also have your heaters playing up afterwards then u will need a new heater switch thing ant rember what its called.
there about £12 off ebay so wont break the bank.
I though it was the passenger door leaking, but i will look in to this also on my car cheers!
