JOM BONNET LIFTER GAS STRUTS
Hi guys, hope somebody can help me.
I bought JOM BONNET LIFTER GAS STRUTS and I put them on my car as it was in the manual, but I can't fully close the bonnet...???
It looks like the manual (complete in german:) of course for 6N and other models is not correct.
I don't now wha to do???
Can somebody help me gyus?
  • Replies 15
  • Views 4.8k
Pics?
I had the same problem when I tried to fit mine - The struts are in the wrong position (I know they look right) BUT the reason it wont close is because the Hydraulic part of the Gas strut is pushed in as far as it goes therefore they will need moving down towards the front of the car. It wont hold the bonnet up as high in the air but will be able to close then.
Hope this makes sense, was hard to explain lol
Harry
Harry
Thanks mate,
this was exactly what I've done :) but I'm not really happy with the overall result..hopefully it will work much better after some time...:D
I have also sent an email to the Ebay seller that the manual is not right and that it should be fitted differently. I also informed him that it was impossible to fit the balls on the cups...lots of hassle.
Here is the reply from the seller:
Hi,
Ok i have looked at what we have here in stock and i cant see a problem with them, The balls fit the cups and the pins then secure them fine yes the instructions are in german but the fitting diagram is clear.
We have been selling these for years with no problems on them but as a gesture of good will i can give you a full refund but please don't blame me for the product as i just retail it and as i said we dont have problems with them, look at my recent feedback on them.
I don't know what kind of people could fit them like it was on the diagram but maybe I'm missing some IQ % :)
I will post some pics tomorrow so u can see guys how it should be fitted the right way.
Matus
Ahh dude i got the same ones.. Had major hassle, One of them is impossible to fit the clip round the ball part.. then i lost the clip lol.
Managed to get the other one on & the bonnet wouldnt close, Ended up in a rage & launched them into the back of the garage.
But i just kinda thought.. have you tryed keeping it in the same bolt hole on the body & attaching it to the furthest away nut on the bonnet(2nd one?)
i dunno if that'll work, i'll have another look later today.
Oh & i translated the german 6n part to english best i could if you want a copy?
EDIT: Heres what i managed to make out...
German
1. entfernen Sie den vorderen M8 bolzen vom linken scharnier (A)
2. Montieren Sie an dieser Stelle den kugelbolzen M8 x 15mm(vergessen Sie Die M8 Unterlegscheibe nicht!!).
3. Entfernen Sie die zweite (von der vorderen Seite aus gesehen) Karrosserieschraube (B)
4. Montieren Sie an dieser Stelle die Kugelschraube (vergessen sie die m6 Unterlegscheibe nicht!)
5. Entfernen sie den vorderen bolzen vom rechten scharnier und montieren sie auch hier den kugelbolzen mit unterlegscheibe.
6. Fur die montage I'm kotflugel rechts soll ein 4mm Loch gebohrt werden auf 400mm von der mitte der scharniere ©.
7. Geben Sie auf diese Stelle eine Antirostbehandlung und montieren sie die kugelschraube (vergessen Sie auch hier die unterlegscheibe nicht!).
8. Schrauben sie die gelenke auf den hoodlift and entfernen sie die sicherungsklammer.
9. Montieren sie den hoodlift (mit dem kylinder nach oben!!) auf den kugelbolzen (diese sollen gut montiert werden)
10. Montieren sie die klammer zuruck in die gelenke.
diese sorgen fur eine gute, bleibende wirkung.
11. Wiederholen Sie das gleiche Verfahren fur die rechte seite.
English
1st You remove the front bolt M8 from the left hinge (A)
2nd Assemble in this place the ball stud M8 x 15mm (do not forget the washer M8!).
3rd Remove saw the second (from the front page) Karrosserieschraube (B)
4th Assemble at this point, the ball screw (do not forget the washer m6!)
5th Remove the front bolt from the right hinge and mount it again the ball stud with washer.
6th For the assembly is in the right kotflugel a 4mm hole drilled at 400mm from the center of the hinges ©.
7th Enter this place an anti-rust treatment and mount the ball screw (be sure the washer is not even here!).
8th Screw the joints to remove the hoodlift and they capture the clip.
9th Assemble the hoodlift (with the kylinder up!) On the ball stud (these should be well-fitted)
10th Assemble the clip back into the joints.
these make for a good, lasting effect.
11th Repeat the same procedure for the right side.
Edited by kc_harty
Man that's pants,I'm in the wrong game. I rarely buy new stuff for mine. I whipped one off the tailgate of a Saxo,used the Saxo ball mounts,and it fitted the original MK2/F holes and works perfectly.
I'm sure the local breakers will have one a suitable length for the 6n, but people seem to wanna pay over the odds for shiny new stuff..
some pics how I done it :)
thanks kc_harty for translating but I can speak and read german :)
Hope this would help somebody in future. (The mesures in the manual are 400mm but it needs to be 450mm) after that u can close the bonnet.
the passenger side one is suppose to go in the wing bolt which you have just put the strut in front of
and the drivers is like 40mm from the 2nd wing bolt from the bulkhead to headlights
hope this helps
That's how I fitted mine! Used the bonnet hinge bolt closest to the windscreen as instructed! But they don't actually lift! Just tried them on the hinge bolt closest to the headlights and the loft quite well but Id hav to drill my passenger wing aswell which I'm not to fond of doing! How well do yours lift matus???
Hi Pepe,
it's not excellent but it's working...sometimes I have the filling that my bonnet want to fly :)
If enybody wants to fit it like the manual says...good luck...but no chance to fit it this way.
Because I wasn't happy I had full refund from the seller. Everybody should let the sellers know that this manual is not OK for 6N.
Matus
  • 1 year later...
this has been a great help to me , but how did you get the bottom strut pieces to hold in position , did you use they screw things or get some more m8 bolts and bolt it under the wing?
Hi buddy,
I have used only the fixing from the package nothing else.
mine are fitted cylinder bolted to the body and they lift looovely!! i pop the latch and they go up like slo mo.
Hi buddy,
can you post some pictures of them fitted?
What make are they?
cheers
there jom or inxx whatever you wantto call them. cheap crap... ye ill post a pic when i put her back together.
  • 5 months later...
got a set off these nearly lobed the fuckers at some one !! stupid fooking fitting book. that spring clip in the cup needs to stay in and you push the thing into it?
