Skolo Coupe
well here is my new polo genesis coupe, its gonna be my runaround while the 6n is being overhauled
its a 93, 1.3l, tornado red, with a tape deck!! retro
after thr first wash, before i got carried away taking the rub strips off
interior being cleaned
all the shite taken out
B.H, Before Hoover
tidy aul boot
cleaning under arches
passenger side
AL-KO shocks :D
took less than a minute to take em off both sides
under the hood, since been tidied
ERRR... new shiney cam cover , oxide on head
after the fudgewheel
had a go at restoring the paint with t-cut, check the difference between sunroof without and the roof after t-cut
tried to do a 50/50 front (right of pic) is done, door side of wing (left) not done
.jpg
before t-cut, dull no shine
after t-cut, check it out
another 50/50
and another
on to the boot, right side done and shiney, rest dull
getting there
up close
N/S wing suffer real bad fading and huge scratch/dent
the door suffered bad aswell plus had tin worm
bottom done, top not
mask it off
Edited by mini_mayhem
  • Replies 167
  • Views 27.7k
  • mini_mayhem
    mini_mayhem
    Well it has been years since an update so: In 2013 I fitted a replacement AFH to cure the burning oil issue, so engine in and tined up, out for a test drive and the diff broke in the box, Change bo
  • mini_mayhem
    mini_mayhem
    Not big update, but the car runs! Over the winter I've got a rebuilt AFH in. I had forgotten how much fun this engine is.   Also managed to get my speedline alloys powder coated, t
passenger door rot
i dont want no overspray fool!
sanded down and first skim of filler
door down, found filler, hint of damage
primered
door inserts were also faded so they got a lick of paint
paint didnt quite match but hey lifes like that
rust hole in battery tray alright
it was an english car before
tidied up well in fairness
i'll finish the bay this week
needs afew lilttle bits and pieces nothing major
Looks like it got potential, Looks like its a very clean car underneath all the dust lol, Can tell its been looked after pretty well, Get a machine polisher on it though, Should hopefully restore the paint pretty well for a while.
Max
the vag gang
the cleaned bay
the dreaded battery tray
as she sat before i took the exhaust and ARB off
the exhaust
the ARB
the manifold
exhaust and ARB have since been painted, pics soon
the exhaust painted and some chrome pipe welded on, for that sport look and an extra 10bhp :D
debumpered anyone
I'm liking it alot especially without the rear boot plinth
how it may look once done minus the lock barrel
taking it off to get at the rust
tip of the iceberg
under washer fluid bottle
the real damage
the bumpers looking sad
looking good mate keep the updates acoming!!!
great work so far, keep it up
This is what I've been up to for the last while in between other jobs
rust cut out in front chassis leg
plate cut, and fitted
disaster that was the battery tray
bye bye rust!
the number plate recess holes welded up
lock trail fitted
rear end before
how it looks now
fitted vented discs but caliper wouldn't fit so back on solids
put new exhaust manifold studs in
tried drilling the sheared stud in manifold
but it reshaped the drill bit
its down at the local enginnering shop being drilled out
i also decided to smooth the rear arches
first welded up the holes and then first skim of filler
primed
painted
looking good pal keep us updated :thumbsup:
not bad gettin some loving this 1 like i actually lke it without the boot plinth looks cool
Very hard working chap arent you mate, Wish i had this much spare time!
Great work so far, id de-wiper the back, makes it look so much better.
i use the rear wiper too much to get rid of it, i live in Ireland, :) plus if i did de wiper it i wold have to smooth out the hole to match the shape of the boot lid,
i only get to spend a few hours here and there, then have to take time out to update the forum.
cheers lads, all the comments are appreciated
isn't there going to be a legality issue with plate lights and such?
looks very nice though.
lite bolts will sort it
Loving that boot. Never seen one done like that before!
lol at the brake fail, you need VW2's to fit vented discs ;)
i have them now, but wont change to vented til next time i need new brakes,
i did the plinth to clean up the boot, enhance the lines
well it is running finally, got a fuel pump and a fresh battery and one it was alll fitted it fired up on the first turn of the key.
the ehaust is fitted, also the rear arch splats (bumper sideof the arch) have been removed.
german font plates will be here tomorrow
paint starting to fade again, :(
its much nicer to drive than my 1L 6n
Excellent work, nice to see someone getting stuck into a car without pissing about with flash wheels and stickers.
Advice: Try not to square mask areas when you are spraying, try and soft (no hard edge of tape) mask/blend in the colour.
Also where you've deleted the trim on the arch I would consider protecting it with something like a textured stone chip, I did mine like you have and it has chipped and rusted.. I don't have mud flaps which doesn't help.
Looking very good so far buddy!
@ mac coll thanks for the advice, any thread i could read to help with spraying? I'm not too worried as it will be getting a full respray when i get cash,
@James Q , thanks man
german font plates are fitted with light bolts, car has been fully service and now only needs tyres and time for nct.
lads just found out tiny pic is no longer accepting international uploads, also they have removed some of pictures hence why they are missing, shame as i have no intention of uploading them to photobucket again, sad loss.
hopefully fitting a 6n splitter soon along with new ht leads and dizzy cap and rotor arm.
i've also added front mud flaps as i was sick of cleaning the car so often.
the rear are are starteing to get stone chips so they will need sorting.
cd player added along with cooling fan to allow it run with heating on
i'm now rocking Mk2 gti seats, such an improvement.
i went cloth over leather just cos i prefer them
it was some mission to get the two top mounts changed, but its done. next time i do that i will do everything, lows, polybushes, wheel bearings, clean and paint, prob during the summer
Looks great. You need to stop masking so close to where you're spraying you'll end up with a patchwork car. Best thing to do is mask another 3-4" further out that you are doing, stick the tape down but then peel the inside edge up all the way round. This will help feather the paint in.
Matt
