Skolo Coupe
The end result of the B*starding at CIT. Why do people feel it necessary to touch/damage someone elses car?
I had to readjust my rear shoes so took the opportunity to to clean out the brake dust and clean up the drums.
Did a bit of painting on the hubcaps
All painted
  • Replies 167
  • Views 27.6k
  • mini_mayhem
    mini_mayhem
    Well it has been years since an update so: In 2013 I fitted a replacement AFH to cure the burning oil issue, so engine in and tined up, out for a test drive and the diff broke in the box, Change bo
  • mini_mayhem
    mini_mayhem
    Not big update, but the car runs! Over the winter I've got a rebuilt AFH in. I had forgotten how much fun this engine is.   Also managed to get my speedline alloys powder coated, t
up on stands foe a good auld cleaning and fixing the exhaust which broke again shortly after
loving all the work your doing :-) doing alot of the kind of stuff i would like to do, all my bodywork is done really just alot of engine based stuff looking good anyway pal
I've a lot left on my list. including respray and engine ;)
Since last time, the standard exhaust has been repaired and raised, car got a service and new sump seal.
and last sat night we finshed up a homebrew exhaust de cat straight through to back box, made from a few other exhausts I managed to get a hold of. Its only for a bit of fun.
Here are some pics of the homebrew, which I ended up having to weld the down pipe to the mani to stop the blowing with all my sheared bolts. the ehaust is after melting the h/brake cable casing so that will be getting a change when I change the exhaust back.
The front seats are out for a wash. some before pics
Fitted a new rear wiper thursday aswell. tidys it up a bit
Tipping away like a small trailer at this while on holidays.
Got a sticker made up for the reversing light, saves the €20 postage from germany and cost of the light.
photobucket treouble with that pic
I tried on the 13s off my Mini , bit lost i think
This lead me to start a refurb on my 14s
This is the finsished they had before I started
so tyres off and a good wash exposed alot of corrosion
small example
on with the nitromors before i started wet sanding with 220. more pics when I get more done.
I also started on a nice little custom touch B)
Edited by mini_mayhem
ta da, the rear light
Have been working on this for the last little while again so its update time
got a little bit more sanding done on one wheel, still 3 to go.
Firstly one night I finally got round to using some balck carpet that was always going to come in handy from a house we were clearing out.
I carpeted the boot albeit badly
next the front wipers were a bit sad so off they came for a quickie spray job.
much improved.
I've had the ides for a full scuttle tray to repalce the piece of plastic for a while now. its all cut and not quite how I planned it, just need to mount it now... few issues with that.
For all my travels i decided a roof rack was a necessary addition. so the citreon dispatch that was lying around for a few years finally found its use. I shortened it appropriately and then made brackets for securing it to the roof gutter.
I also aquired an AER cam/rocker cover so its's now tarted up awaiting fitment
The homebrew exhaust came off and the 'lifted' standard exhaust refitted along with a new handbrake cable. the brake fluid was also renewed , long over due.
Yesterday evening I went rolling my rear arches with my not quite up to the job arch roller. so modifications were made. and the two rear arches proceeded to be rolled and then primered.
The arches are all tied sealed and red again now. (with a white line ...... I ran outta paint)
Any chance you could get me the part number on these....
Should be on the back of them somewhere.
Would be a MASSIVE help if you could :)
Well I got the mad notion one night I want lights in the boot so I set about it.
I cut the door switch from a starlet.
The switch
Then proceeded to cut up the Skolo
and weld in the nut from the starlet
I then gave it a dose of filler and sanded it in, must get paint and wire in the lights too.
I also finished sanding the alloys and managed to paint them this evening. I couldnt decide what way to do them so . . .
thats where its at. it would be a miracle to get these on for fermoy.
and the interior got a good cleaning in early show prep.
right i got my scuttle tray finshsed
Heres the scuttle tray in all its glory
The rear brace I've just finished making a rear brace and the front one
post 49 here http://www.clubpolo.co.uk/forum/index.php?...81707&st=25
( why the blocks you ask? how else would you lower it?)
and the front
I'm pretty happy with how they turned out.
oh and the other project I was working on, just painted.
started work on another mod tonight, not sure how it will go but stay tuned
wish my car sat as good as this, mines 80/80 and it looks dyer compared to this haha
I'm down 60 at the rear
155/70/ 13s aswell
spent the day getting rid of the patches, so the car is more or less one shade of red again.
60 on the rear?! Mines like that and mines an 80kit with the same tyres
yeah just 60 on the rear, no spacers or anything
here are some of the pics
this was behind the number plate, yuck
all wet sanded down
primed and painted
then all the over spray was removed with rubbing compound and the final coat put on
no more patches yay
I'm very happy with how it turned out this time
oh and i got a vent put in the 6n rocker cover
ta dah, it will need repainting at some stage too. :(
and a teaser
http://i860.photobucket.com/albums/ab168/Ryan_D_Duffy/Mk3%20Polo%20
Heres a few from VAGE 2011 and with Baz and Donie
I'm now a surrey dub :p
E P I C build man!!!
get some euro wheels n will look amazin with that roof rack! :thumbsup:
i like the scuttle mate, thought it was just carbord with layers of fibreglass. but thats alot more work than needed. just use perspex?? lol
not so sure about the smoothed side repeaters though, what u doing for the legal???
I only had the rack on for moving to England, its off now, I'm hoping to get my alloys on very shortly
i had the metal lying around so i used it, i know a lad with a G40 who is doing perspex so we couldn't be doing it the same.
i'll cross that bridge when i come to it.
right so
i have a boot light wired up
two pudddle lights
and alloys fittting tuesday, Arb blocks soon as too.
lot of progress but no camera
looking for a set of these too
