2003 VW Polo 9N - Fault codes
Hi Guys, this is my first post.
I have a 2003 Polo 9N 1.2 (yeah i know!)
I am having problems starting, sometimes it starts fine, but idles a litte bit high, and other times it just stutters and dies. I have ran VAG-COM and these are my fault codes:
VAG-COM Version: Release 409.1-S
Chassis Type: 9N - VW Polo
Scan: 01,02,03,08,09,15,17,19,37,44,45,46,55,56,69
Address 01: Engine
Controller: 03D 906 032 C
Component: 1,2l/2V SIMOS3 00HS2501
Coding: 00031
Shop #: WSC 00788
WVWZZZ9NZ3Y243932 VWZ7Z0C6763596
4 Faults Found:
16500 - Engine Coolant Temp. Sensor (G62): Implausible Signal
P0116 - 35-10 - - - Intermittent
16686 - Cylinder 2 Misfire Detected
P0302 - 35-10 - - - Intermittent
16556 - Fuel Trim: System Too Rich: Bank 1
P0172 - 35-10 - - - Intermittent
17658 - Fuel Level too Low
P1250 - 35-00 - -
Readiness: 0000 0000
Address 03: ABS Brakes
Controller: 6Q0 907 379 L
Component: ABS FRONT MK60 0101
Coding: 0001097
Shop #: WSC 00788
No fault code found.
Address 09: Cent. Elect.
Controller: 6Q1 937 049 C
Component: 00 BN-SG. 1S33
Coding: 25742
Shop #: WSC 00788
2 Faults Found:
01336 - Data Bus for Comfort System
49-10 - No Communications - Intermittent
01598 - Drive Battery Voltage
07-10 - Signal too Low - Intermittent
Skipping Address 15-Airbags
Address 17: Instruments
Controller: 6Q0 920 900 H
Component: KOMBI+WEGFAHRSP VDO V15
Coding: 01431
Shop #: WSC 00000
Address 19: CAN Gateway
Controller: 6N0 909 901
Component: 10 GATEWAY CAN 1S33
Coding: 00014
Shop #: WSC 00788
1 Fault Found:
Address 44: Steering Assist
Controller: 6Q0 423 156 AB
Component: LenkhilfeTRW V270
Coding: 10110
Shop #: WSC 00000
Address 46: Central Conv.
Controller: 6Q0 959 433 G
Component: 41 Komfortgerát 0002
Coding: 00017
Shop #: WSC 00788
End --------------------------------------------------------------------------------------------------
I would appreciate your help very much as I am not too good with cars!
Andy
Edited by legenderi32
  • Views 13k
clear the codes and run the car for a couple of days and re-scan. the ones showing now might not all be current faults.
Cheers for replying, ok i've cleared the codes. I'll post them again in a cpl of days and c wots coming up then.
Without doubt your fault lies with your coolant temp sensor.
I have 1.2 12v 9n2 and the same problem. Idles too fast and you find if the engine is warm it is very hard to start.
Easy job to do. Locate sensor and remove wiring plug, remove underpanel from front bumper to provide access to coolant drain tap and drain coolant. Return to sensor, remove retaining pin and remove sensor (just pulls out) fit new sensor ensuring to use new seal, insert pin, close coolant drain tap, replace underpanel, fill coolant and watch the fault disappear!
20 min job tops!
hey guys cheers for your help.
I have ran the car for about a week, engine management light came on again, ran VAG-COM and here's what came up:
Control Module Part Number: 03D 906 032 C
Component and/or Version: 1,2l/2V SIMOS3 00HS2501
Software Coding: 00031
Work Shop Code: WSC 00788
Additional Info: WVWZZZ9NZ3Y243932 VWZ7Z0C6763596
2 Faults Found:
P0116 - 35-00 - -
Is this definately the coolant sensor? I have replaced the coolant sensor before, but i did not drain and top up the coolant. Thanks!
