Broken into...
Went down to Nottingham for a couple of nights and got broken into. Car can now easily be locked or unlocked with a screwdriver (or anything else that fits in the hole! :lol:).
I'm guessing it wont be cheap going to the dealer, as the lock will be specific to the key.
Would it be better to try find replacements at a scrappy? And would I be able to fit them myself? I'm a novice when it comes to stuff like this.
Or should I just block the hole up somehow and smooth the handle? I'm a student and really need the cheapest solution possible! :-D
Thanks.
  • Replies 8
  • Views 1.4k
I'm guessing its a 9n?
Correct.
get an aftermarket central locking kit and get some smooth handles on it =D
there about £30 max from r-click =D
least they didnt take the car :D
buy a new set of handles with keys from ebay? thats what i did presuming they arent coded
mine was 6n2 though
if its a coded one, you could pick up a set of door handles and replacement ECU
If it's passenger side could you not just get a rear door handle and put it on the front?
dont think it works, i tried to do this on my mk3, using mk2 golf rear door handles, the catches on the inside mis the mecanissm on the handle because of the door pin position being at the front of the door, not the rear. Could be different on these tho. I've had my car broke into similar to this aswell, they just ripped the handle off with a screw driver and opened it with the latches underneth the barrell.
could it not of had more to do with the fact you were using door handles from different car's?
or could it be that you were being a spoon and forgot that to fit mk2 golf rear handles to a mk3 polo you need to swap the striker pin over. Loads of people have delocked mk2 and 3 polos using mk2 golf rear handles.
