Driver's Door Wont Open
When me and my grandad was sorting the little repairs on the car ready for the MOT, we then started to sort the door cards from coming off. Then i noticed the door lock retaining nuts wasn't there, so i replaced then and tightening them up. Then we closed the door and tried to open it, it wouldn't open so we tried opening it from inside and that would't open. We took the door card off when the door was closed, and pulled the linking rod to see if the door would open, but it's not even moving. It's like the door is stuck closed.
Any help would greatly be appreciated
  • Replies 9
  • Views 1.4k
have you tried locking/unlocking it?
Yes, i have mate
try removing the rod then getting a screwdriver or bar to move the latch,spray some wd40 in there if possible
unlocked a friends corsa that way when he got locked out
Well, i can pull the rod and the latch moves with the rod but the door still doesn't open.
aahh ok
dont know what else to suggest mate,except pulling the rod and giving the door a good boot outwards to see if it will budge
aahh ok
I've also done that mate, this all started when i put the lock retaining bolts in
Can anyone help me?
Thank you
Mike
Does anyone know how to sort this out?
It's really important, my MOT is due in 3 days :(
Thank you
I've had my car in the garage and they got the door open and said the locking mechanism needs replacing, so i'm getting that fixed tomorrow.
Edited by Mike1990
