smoothing and the law
Right, my cars going in to the bodyshop for some smoothing, the front number plate recess is being smoothed off but I have no where to put my front plate, any ideas? I also want to weld the boot plate recess up but I no I have to have the lights for te plate, what's the consequences if I get caught without the lights?
  • Replies 10
  • Views 2k
probably a fine and points, I'm sure you could come up with a way to put the lights somewhere
number plate lights are an MOT requirement
http://www.ukmot.com/mot_check.asp#information7
No MOT = Not road worthy = No insurance = Ass Rape By Police
Edited by residentmelon
The front plate can be anywhere as long as its in front of the front axle and visible.
The rear lights aren't hard at all. Just need to find a suitable light or 2 (usually from motorbikes or the like) and then re-wire.
Buy a white LED Strip from EBAY, line across the top of plate. Job done.
is that legal, because that seems the easiest option and just take it off for shows
I've never undrstood this,and think it looks stupid to get rid of the recess only to have the plate put on as an afterthought.
But you dont want my opinion,you want answers to your taste.
Well i cant help with that,but why not do something different to last seasons generation of so called 'chav' mods? How about thinking outside the box and coming up with something that will be interesting instead? Different? Inventitive? And make sense?
Like,if you dont like the standard recess,get a different one welded in. I think the late '90s 5-series one would be nice,complete with crease from light to light. Now that might get a better reception at shows.
I might be wrong,you might not agree,but its a thought.
the light cant be dazzling to other road users, thats why it points at the plate and not back at the car behind.
you could/can buy replacement bolts for your plate that have lights. just wire them in & problem solved..
as for the front plate, like clarkson20 says.. best to work it out before you smooth the recess =P
hiya i done this on mine used numberplate bolt lights and made some spacers:D
thanks
jamie
i'm smoothing my front bumper atm but i'm leaving the plate recess in, i don't see the point in having a nice looking bumper with a number plate that has nowhere to go stuck on it some where making it look untidy, i'd rather have a proper place for it to go that makes it look a lot neater.
