Do i go for a 6n2 GTi?
Chaps
My mrs is looking for a new car after her 6n 1.4, and I've been looking at a 6n2 GTi as a logical step up as she wants to keep to a hatchback and keep it a good few years.
Now how regualar are these gearbox problems? and do vw still honour pedalbox warranty. Also any other stuff that is common and generally how is ownership of these?
Anyone in the know i would be very grateful for the advice
Arran
  • Views 1k
Chaps
Arran
Mines currently on 112k and is 10 years old. So you have to remember they are not new cars any more.
Only issue I have had is the clutch going and an annoying emissions light on the dash (turns out the light was caused by cut wires on the lambda which were caused when the gearbox was removed... All my fault but is a known common fault). But.. The clutch was original at 112k so can't complain.
As far as the gearboxes go.. As long as they are maintained and checked properly there are no issues. Mines the original gearbox and has no issues, but others have failed from 50k+ (my mates owned one from new and I remember his whirring from about 35k, but it's still alive at about 70k because he drives properly, i.e no ragging etc). So it all depends how its been driven. I would recommend checking to see if the seals (especially the selector rod) have been replaced and/or are leaking.
Now, the pedal box issue is a funny one.. Some garages honour, others don't. But they should honour all GTI's for this repair. You can easily give a dealer the reg number to check whether the work has been carried out or not. The main reason for pedal box failure is a worn clutch.. Instead of the clutch/cable going, the pedalbox seems to. Check for a heavy clutch as its that which causes it.
EDIT: Other common issues are bubbling of the rear spoiler and gutter trims, one touch electric window function playing up (requires new switches - cheapish), auto headlight adjustment failing (1 tiny clip within the headlight which can't be bought separate but can be swapped from a non-xenon = cheap but annoyingly hard) and Cambelt tensioner failures from about 40-50k (check for a noisy, tappy engine). TBH, they are pretty bullet proof if looked after and serviced correctly when they should be.
They do have the odd issue, but what car doesn't... Mines the best/most reliable car I've ever owned.
Edited by MrP
This giude should help you out:
http://www.tigerstyle.co.uk/phpBB3/viewtop...f=7&t=35521
Also, a cheeky advertisement of mine. I have mine for sale in the for sale section - recon gearbox a year ago and the cambelt and tensioners just been replaced :p
this is getting to the point where this is asked every fucking day
do some freakin searching!!!
As Neil said, please use the search function as this gets asked time and time and time again!
