Replacing 6n/6n2 Aerial Bases
I remember ther being a thread on how tochange these with the part numbes etc... Just looked through 20 pages on the search function but no jy, cn someone give me a hand?
Steve.
  • Views 4.9k
take the rear plastic strip, that holds the headlining up, off. and maybe the c pillar trims aswell both just clip on pull the headlining down be careful not to bend it though! use a ring spanner or small socket and rachet (22mm) i think and undo the large grip nut un plug the joiner wire and remove the areila from th roof, all done! idealy to remove the headlining would be better but you can just about do it wit it in
Cheers mate, ill have a go :) But i thought there was a thread on here not long ago with part numbers etc...?
Here you go mate. Should be around £13 from the dealers.
Thats what I was looking for, legend!
Cheers beyyy :thumbsup:
