Filler/Nitromors Question
Hi all,
got a 106 i'm building up, its got a hell of alot of parking dents (funfunfun). I cant be bothered to sand all of them down to metal for the filler to grip to properly, as it's all got ot be done by hand (no power in my garage :(). Can i safely use nitromors in the affected areas to remove the paint? I know loads of you guys use them on wheels, and the paint adheres fine after, so will i be safe?
Obviously i will use it carefully and if it doesnt remove all of the paint i need it to then i can sand the final bit off.
Thanks guys.
  • Views 857
No one? Oh well guess i'll find out the hard way!
Well so far its eaten through my paint as expected :) Now just to test that the filler grips and i can safely primer over it.
it should grip ok. I'd give the metal a quick sand after taking the paint off so theres something for the filler to grip onto otherwise the first bump it'll either crack or drop out.
Done that :) It's only small car park dents anyway, but I'm more concerned about after i re-prime/re-paint it, will it come through the paint? I've started doing it on a test panel anyway so i'll know soon but I'm just wondering if anyone had experience and tips.
