6n2 with gsi slabs?
i would like to know if my 6n2 2000 vw polo is able to be fitted with 15'' gsi cavalier slabs?
i dont know any of the other measurements bout would like to know in advance before i travel brave distance to look at the alloys.
cheers in advance:D
  • Views 296
They'd fit pcd and size wise, not sure about off set though, I think vauxhalls have quite high offsets, so you could need some spacers
think you may have wrong section dude..
yeh can fit but center bore needs opening up a touch from vauxhall 56.6 to vw 57.1 can do it with a flap sanding wheel and a drill.. not hard
the cav slabs are et 49 so might need spacers to bring them out a touch
think it would look sick if the colours were right
If cav slabs don't work, try Estorils, pretty much the same design :)
