Anyone with a MK3 Square running H&R Cup Susp?
As the title really, just want to see how it sits!
  • Views 1k
It will sit depending ont ride height wont it?
Has 2 settings, 60/40 and 60/60.
Wonder if I will get away with running standard G40 RA's (175/60/13s) on 60/60.
I was down on a Phill j kit by 60/40 and ran 185/55/14 and was minor scrubbing. Only after basically gettin air of a speedbump or my girlfriends fat mate in the back and going over potholes.
The phill j kits are much harder than the H&R kits so you might bottom out easier than me.
I'm sure you'll be fine.
id say youd be fine with 60/60 with standard g40 bbs mate, they tuck nicely in the arches, and i never had rubbing problems with my hnr kit on the mk2 coupe and it ran the same wheels and tyre sizes as my current coupe on a kw kit (which now does rub when the back is loaded)
