Lighter Paint behind polo badge, Help!
I have done a search but found no one coming to a conclusion on this...
I debadged my car today, removing the letters and the sticky stuff after it with clay bar.
I then found the lighter paint so i clay barred it some more then used T-Cut on that area. This didnt do much atall so i tried scratch remover and also red polish... Stil to no result, i was wondering if there is anything else i could possibly try and if not i suppose the badges will have to be put back on..?
Any help would be much appreciated...
Thanks, Adam.
Edited by DJ A-Jay
  • Views 1.2k
Same happened to me, but i think eventually it fades a little bit. Plus it is kinda one of those things where you see it because you know its there, i totally forgot this happened to me until you reminded me lol.
You'll probably find the basecoat hasn't faded so much under the badge. Even if the car is laquered, the base can still fade. Thats why T-cut etc yeilded no results, you were polishing the clear coat. It'll fade in time and be less noticible to the eye :)
Hope I helped!
Hope I helped!
Thanks for the help lads! Much appreciated
G3 that shit!
Haha, G3 won't work man. You could use a polish designed for Titanium, and it wouldn't work.. Well unless you wanted it to bare metal.. :ninja:
Is it not aged or weathered lacquer? if so you could flat it back with some 2000 wet & dry then g3 it back?
shut up and G3 thats shit so we can end this post
