mot... not good!
my 1999 mk4 1.4 polo has just failed miserably.. gutted! and i cant afford to get it repaired, cat converter just non-existent... nearside suspension arm corroded..brake lines..etc...
would it be worth breaking.I'm not mechanically minded either.. so i wouldnt know where to start!
I've also got a set of brock b2 supercup alloys... that i would sell separtly but I'm unsure on price.... 2 good tyres,2 with not much tread, been used everyday so abit of curbing here and there.
get some pics of the car up in the for sale section and we can go from there
Doesn't sound all that bad.
As long as the rest of the car is reasonable, it should be worth saving. Are you any good with a spanner? None of those are particulary challenging jobs.
The cat will be the most expensive thing but you might be able to get one cheap.. or even a good second hand one. suspension arm corroded probs just means surface rust. Get a wire bush and clean it off or if its it bad buy a new one and follow haynes to replace. Break lines not bad either and they are easy to replace.
All in all not bad. and worse case I would say all do able for not much money.. worse case sell the wheels to fund it :)
thats not bad! you could source the parts for about 70 and a cat for about 150, save the little olop :-(
