sunroof leaked!
had my car sitting at work all day long from about 8.30 till half 5. as i started to pull away loads of water leaked from the sunroof and luckley went all over the passenger seat and not me. what ca cause this
I've had a look and the seal looks abit old and not very nice. could a old seal cause this??
if so where could i get a new seal and how do i change it?? the seal is on the sun roof not the roof of the car. so when it is wound back it dissapears under the headlining.
the sunroof has a small lip on it that the seal pushes in to.
chears
  • Views 1k
bump
gettin wet!!!
I'm not an expert on this, but the seal on my bready sunroof is fine- and no water gets in. So i would imagine if your seal has badly perished/split etc it's likely to be that, because as you say the water comes in when you drive off..it's likely to be gathering in a part of the perished seal? If you take your sunroof off I'm sure it would become apparent where it's coming in :D (if theres an obvious hole lol)
is it a factory steel sliding roof or an after-market glass popup one?
If the former then possibly down to blocked drain pipes. The seal isn't water tight anyway it relies on the water draining away down these pipes. There's one in each corner of the sunroof, poke something long an bendy down it, front ones pop out just behind the front wheels, rear ones behind the rear wheels.
If it's an aftermarket glass one then it probably needs a new seal but you'll need to find out the manufacturer of the roof first, then try to find out where a new seal can be bought. If the problem is a split in it then you could just bodge it with some silicon or something.
standard fitted one ill have a look ant see of the pipes are blocked when i can find something longenough lol
