Shed clearout!
Having a clearout so here goes. All parts are located in Skegness, Lincolnshire. PM me with any questions or offers. All must go!
6N Polo
6N 1.4 8v driveshafts for non ABS models. £25 each posted. Buy the pair £30 posted.
6N driver's side driveshaft, was going on a 1997 1.4 8v but never fitted. Very good condition, marked P5 ALD from Stevens VW breakers. £30 posted
6N passenger's side driveshaft, was going on a 1997 1.4 8v but never fitted. Very good condition, marked P5 ALD from Stevens VW breakers. £30 posted
Lupo parts, All parts from a 2002 1.0 E, engine code AUC and have covered just under 33k Some fit 6N and 6N2
L/H head lamp £15 posted one mounting lug has been snapped off the top
R/H head lamp £15 posted
R/H door, some dents in soft blue with glass and manual winder mech £25 collected
Front panel £25 collected
Complete pedal box, drive by wire throttle £30 posted
Dark grey carpet £25 collected
Dark grey boot carpet £10 collected
Seats £50 collected
Dark grey centre console £15 posted
Dark grey parcel shelf £15 posted
Heater controls, non A/C model £15 posted
Dashboard clocks £30 posted
In-tank fuel pump and sender assy £30 posted
L/H door mirror, manual adjust with soft blue cover £30 posted
Air bag ECU module (part no 1C0 909 601) £30 posted
Headlamp switch including heater vent, dimmer and level adjuster £25 posted
L/H window winder assy £20 posted
Clutch cable £10 posted
Dark grey lower dashboard bins £25 posted
Cooling fan £15 posted
Gearshift cables and lever £35 posted
Front upper bumper, scuffed so needs painting £10 collected
Radiator £25 posted
Tailgate including glass in soft blue £25 collected (lock barrel not included)
Rear axle including drum brakes and handbrake cables £40 collected (Does not include shocks)
Power steering rack £50 posted (Does not include wishbones, subframe or anti roll bar)
Power steering pump (part no 6N0422155E) £25 posted
Alternator 70 amp (part no 037 903 025 S) £40 posted
Passenger side driveshaft, non ABS £40 posted
Driver side driveshaft, non ABS £40 posted
Drivers side hub assy, not including the caliper £40 posted
Coolant header tank and hoses £15 posted
Washer bottle and pump £10 posted
Engine ECU (part no 030 906 032 CP)£40 posted
Front struts, springs and top mounts £40 posted (only done 21500 miles)
Horn £5 posted
PAS Fluid tank £5 posted
Cat converter and post cat lambda sensor £50 posted
PAS pipe from pump to the rack £30 posted
PAS pipe from rack to the fluid tank £15 posted
Rear bumper £20 collected
Starter (part no 085 911 023E) and wiring £40 posted
Brake servo and master cylinder £30 posted
Exhaust brackets £7.50 posted
Bonnet, damage around badge relief £15 collected
Drivers side wing, will need painting £15 collected
Air filter assy with recent filters £20 posted
Complete engine bay loom £25 posted (Alot of wire for the money!)
Don't be scared to make me offers! Go-on try your luck! :lol:
Edited by 86Ctom
  • Replies 8
  • Views 706
now then kid will the lupo clock and dials fit in a 6n thanks
not a sniff
Interested in the rear bumper, will find out if it could be fabricated (6n2) and let u know mate!
Sorry mate but it won't fit. Clocks may work in a 6N2 tho.
dont suppose you would post the rear bumper?
BUMP
Do you have the trim from the inside of the boot, very interested in that. Also I have a mate who would be very interested in the bonnet.
Only whats in the pics now guys!
