Gear Knob
hi all
My knob is split :lol:
and my gator is tatty :oops:
How easy is it to get them off and what sort of replacements do people use?
  • Views 799
I also have a split knob :oops:
To remove it you need to take the gator off from the base, and pull it up over the knob. There's a metal clip you'll need to open up.
From what I've seen, mk5 6N2 Polo ones fit, I think mk4 Golf/Bora ones go on too.
Interested to see what OEM stuff other people have used though, as I need to change mine too.
i drilled a hole in a golf ball 8-)8-)
looks and feals great.. :grin:
i used a bora/jetta one, its very similar if not the same as a Mk5 polo one but it went on easily enough. bought it for 99p off the bay! You just need a small jubilee clip to replace the metal ring that stops it from twisting, hope this helps
