Mk3 or Late Mk2 handbrake lever mech
Need the handbrake lever and also section of exhaust tunnel that it mounts onto from a mk2 '85 onwards or any mk3. You need to cut it from a shell, i can't get a cutter to the scrapyard so need someone to cut it from their scrap shell! So I can weld it into my Mk2.
Can anyone help?
Edited by Narrow_Lane
  • Replies 13
  • Views 1.7k
The lever bolts onto the car. I've got one here, could also possibly cut a section out of the tunnel if required
yea sorry should have worded it better, I don't think you can swap the levers, it's the whole mech from the tunnel (to fit a late tank to early mk2). if you could do this that would be awesome
i've just had a look on etka, and it looks like the actual handbrake is the same part number on mk2/3's. pm me with any bits you need?
PMed! :)
bump
bump :sad:
bump
just swap the cable set-up mate....... the handbrakes the same but cable different
oh right in that case I'll grab a cable at GSF tomorrow cheers dude
bump the handbrakes are different. mines early mk2, shares the handbrake part no. with a mk1
can send you a handle and cover trim for £8 posted
also have the 2 wee cable brackets (cages) for next to the fuel tank if you want them too for an extra £5 or if you want a powder coated black version for an extra £8
thanks, but I really need the part of the tunnel as well, so if someone can cut it out of a scrap car can probably supply the lever. will let you know if i need it.
I've got the cage bits already cheers.
There's a Mk3 at a scrapyard 20 miles down the road so I'm on the lookout for a portable grinder to cut it out, unfortunately no-one I know seems to have one
think I can help you with this! I've got a lever and about a square foot of tunnel with mountings etc on. (off a mk3) got some cables too - not sure which though. Think the long one's in-tact. I could sort you a pic out today if you want. Let me know.
