Stearing Column Replacement
I have a Mk3 1.0 L Polo and it has a little bit of a clicking sound coming from the steering wheel. I have been advised that this has something to do with steering lock and I would need to replace the whole column to resolve the issue.
My question is, is this a big job and how much do you reckon it would cost? I have been looking at buying the column myself and then paying someone else to fit it.
Also, would it be the same steering column for all Polo's of that era or would I need to look out for one that came from the same car as mine?
Thanks x
I've never heard of it,but it sounds scary to think it could catch enough to lock when driving.
Could be something else,like the indicator stalk mechanism,but if you can source a column they're surprisingly easy to change.
Check the bolt and the end where it meets the floor,in any case.
Yeah, but we reckon it's been like that for a couple of years. Someone tried to break in to it a couple of years ago and we reckon that's when it happened.
If the steering column isn't that difficult to replace I think I'll get that done, but I'm no expert and I don't want to buy one to find it's the wrong type!
Thanks for your reply :-)
recently I had to remove the steering column to get the pedal box out of the car. Same model of car. Removing the steering column was a very difficult job. There are 2 "sheer" bolts at the top of the column that hold the column to the bodywork. these had to be grinded off. The only way. I had to attach a small 30mm grinding stone to a drill to get this done as there is no room for a conventional grinder to the job. But get these bolts off and its easy. remember to dissconect the battery when doing this job as a lot of the work takes place next to the fusebox. dont want to be blowing fuses all over the place!
