Water on drivers side....
Hi
i dont actually drive my mk3 polo now but just went and looked at it and the drivers side is full of water!
i took the seat out and pulled the capets up, it was like a swimming pool in there, iv dried it out with a vet vac,
i never had this problem before when i was using the car!
and cant work out where its coming from,
anyone got any ideas where its coming from?
cheers :)
  • Views 851
Check your battery tray, a likely rot spot to fill your floorpan with water. If it's not that, then check the door drain holes and foil behind the door-card.
Ah didnt think of the battery tray!, it was solid last time i looked at it a while ago! lol
Hopefully its not the tray, they are a bit of a sod to repair. You could try removing the underdash tray on the drivers side and looking up at the back of the battery tray. Any holes should be pretty obvious. The one on my derby had rotted so badly that the battery was sitting on the pedals, lol.
