ATS CUPS -CENTER BORE
Just had my new ATS CUPS delivered on Friday, what a nightmare - 1st, Tyre - mounted wrong way round, so had to pay to have these remounted correctly, then had to have them all re-balanced as completely out - as weights were hanging off them when I unpacked them -
Anyway, thats not the main issue - Spigot rings supllied which are 57.1 - fit the wheel hub perfect but not the ATS CUP centers - two big - slightly -
Whats the measurement of the ATS CENTER bore - does anyone know?????
many thanks
MD1 :?
  • Replies 11
  • Views 5.3k
Centre bore for Cups is 57.1, you won't need the spigots
how was the tyre mounted?
Tyres are directional, one was put on wrong way round!!!
As advised I know the wheel hub is 57.1 and the spigot rings supplied are 57.1 and fit the wheel hub perfectly, however the spigot which is 57.1 does not fit the ats cup center bore, its two big, so I need to get a spigot ring set that is still 57.1 but slightly smaller internal fittings so will then fit the wheel !!!! God I think I'm going mad - and yes ived tried to fit the ats cups without the spigot ring and I'm not going down that road, far to much movement, need correct spigot rings, I'm peeved off, do these wheel companies not check things before they courier?
I'm confused.. polo centre bore is 57.1.. ats cups are 57.1.. why do you need spigot rings?
No - Wheel Hub is 57.1 - but ATS CUPS are not 57.1.......
Anyway thanks for comments but just spoken to providers of the wheels, they sent me the wrong Spigot rings they advised - correct ones in post today...so lets hope all ok, other good news - they refunded me £35.00 for having to get wheels re-balanced and tyre sorted.....so all is good. I hope...better not speak to soon..!!
I've got ATS Cups, the wheels have a centre bore of 57.1, and so does the polo. I cant understand why you need spiggots unless the wheels are second hand and have been bored out :?
i also have ats cups.. and they fit lovely.. as far as I'm aware if they are 4x100 they should be 57.1
glad its all sorted now anyway
peace out
Or they're not made for a VW.... :shock:
wheels are brand new from Rimstyle, spoke to them today, all sorted, they admitted they had sent the wrong spigot rings, and correct ones will be with me tomorrow, should look good as 185-45 tyres were fitted. :smile:
The point i was getting at mate was that they are made a WITH VW
fittment,so why is he supplying you a set that AREN'T VW fittment?
Surley it would have been better to give you the correct wheels for your car...
