MK3 Front Panel
Decided to resurrect my GT Shedvan from my parents drive. Doesn't need much work at all.
One thing that always bugged me was the front panel was bent so my grille and bumper wouldn't fit properly.
How to replace this panel is what i'm after basically, think i've read up that you have to drill out the spot welds and you can bolt the panel in like a mk2 golf?
  • Replies 8
  • Views 1.8k
it's spot welded on so yeah you have to drill or grind the welds off. You can tell where the welds are because there's little indentations in the metal.
The replacement on is also designed to be welded on but you can drill holes and bolt or rivet it on. I riveted mine on so to remove I can just drill the rivets out.
martin I've got to dsp this on mine this weekend right if you take the bumper off there are two screws at either end under indys and then there is six spot welds just under inside of headlight and four more under grill and also i think it maybe welded to the inner wing at the bottom and it is also welded to the coverplate for the bonnett latch unless your unbolting the slam panel and taking that out too its a pig of a job to do for such a lil part tho really you could do with a welder and just grind it of and weld new one in
Cheers for the advice...
Where to get a front panel from is the next question... Hadrians? I'll take a look.
edit: This is what I need:
if youve gotta drill the old one out.... id plug weld the new one on, its obviously a structural panel
Anyone used the hadrians part, any good?
yeah it's fine. It's not a part you can really see anyway apart from the small strip under the grill/headlights.
yeah i need to do the same on my polo :? could you let me know how this goes please, i need all the same part you do too so if you could let me know how Hadrian Bodypanels goes awell and the costs of the parts :-) need some advise on what todo really, do i get new part of just pull it and make the best out of it??? hope the pic dosent mess up the posts (I'm new to posting on here)
Looks like you might just get away with this panel, available from Hadrian's (when they have it in stock) or VW (if they have decided to start making them again), or get one from a scrap car
Really depends on how good a job you want to do with your car, whether you try and fix it, or replace it
