ghetto arch rolling
I have decided that because i cant afford to get my arches rolled I'm going to do it myself with a heat gun and a rubber mallet any tips before i start? i have used the search couldnt find much so if anybody has done this some tips would be brilliant
  • Views 1.4k
i used a grinder and that worked well...
every 1 on here said its pikey and will come out shit..... but they were wrong
what and just cut the inner arch? i was planning on just bending it
just the lip.... and protect it so they dont rust through....
i dont think i have the testicles to take a grinder to my car, just try the mallet thing 1st then if all else fails...
I use the pickey method of using a scaffold bar! but i have arch trims!
scaffold bar works.. baseball bat works.. hammer will work but you might get a bit of a bumpy finish ;)
i would suggest a combination of the two.. take the wheel off and (making sure the car is good and sturdy..) use a hammer to know the inside of the lip up but just the lip! not so hard as to actually change the arch..
then put the wheel back and lower the car down again.. insert baseball bat into arch and drive backwards and forwards whilst your mate bend the bat outwards
what a laugh..
I'm sure people will tell you a better way of doing it.. but there you go
rent an arch roller and do it yourself or do what i did and buy an arch roller...mine have came out alright and so has my friends 106...if you were closer I would offer the use of it, though your welcome to come visit and borrow it
