gloss ?
is it possible to spray my car with glosss spray paint in a rattle can instead of matte paint in a rattle can ??
  • Views 1.3k
you can but it will be extremely difficult to get it right as any flaw in matt will show 10x in gloss
Try to get all the cans from the same batch - the batch number should be on the can.
When the car is carefully sprayed,preferably in the warmest most enclosed room you can find (spraying outdoors you're pissing in the wind),and its hardened after a few days,you should wet flat the surface with ultra fine paper (at least 1500 but preferably 2000 grade) and soapy water,then buff it back up to a shine with G3 or metallic T-cut before buffing to a better shine with a polish (like Autoglym super resin or Meguires).
surely if you rattle can your car then the paint will flake off when you wash the car?
Not if you sand the car and prep it before applying the paint.
Its not really worth the hassle mate, lots of work envolved, if you're using a rattle can you will notice patchy bits on the pannels, also you will have lots of 'fish eyes' all over the car. Best thing would be to prep it yourself and send it to a bodyshop and get them to blow the paint over.
if you do decide to do it i wouldn't use conventional spray, it's not very thick and rattle can laquer is fucking shit so even if you do a good job with the base colour it could all go to shit with the laquer.
i did a little trail on the boot of my scirocco using some paint i picked up from B&Q, it's designed for use on metal gates and the like, and it doesn't need to be laqured to be water tight, plus it's very tuff once dried. baring in mind that i sprayed this outside (as mikey pointed out it's like pissing into the wind) and in the dark, it really didn't come out bad at all, here's a photo
with a bit of time spent flatting it back with some 2000 grit wet and dry and a polish with some G3 as mikey recommended i think it would turn out pretty good for a rattle can job tbh. if you took your time with it and sprayed it in a more suitable environment there is no reason you couldn't get a good finish on it and it's certainly a decent alternative to just rattle caning a car matt black.
the paint i used was called 'Metal Protekt' btw.
