15 x 6 alloys what size tyres? help
i have bought some mk 3 golf cab alloys to go on my 6n they are 15 x 6 and i dont know what is the best size tyre to go for
please can anybody help ???
cheers
  • Replies 9
  • Views 2.7k
cheers
195/45/15
cheers
195/45/15
thanks
i keep seeing 165/50/15 , are these better ????
Its up to you, i'd go for 195 45s and have the extra grip
will this result in me raising my ride height as it is on coilovers to allow full lock e.t.c. ? due to having the 195 tyre
also i will be wanting the stretched look as much as possible on the 6j rim
Edited by Razbo91
if you want stretch you'll need wider rims! 165/50 might give a slight stretch depending on the make. think i would rather run 195/45s though
A 6j rim is 150mm wide, so 165 tyres wont give stretch on it! Loads of people run 195/45 15 with lows, so it shouldnt be a problem unless you're down 120mm ! I just hate driving around on uber skinny tyres
thanks for the help
ill just scrap the strech idea and go for the 195/45 then
depends on the make. one of my friends has a silver squareback with a set of teardrops on it. 6j wide. the rear tyres are federal 165/55s and like you say dont have any stretch. his front tyres are bridgstone 165/55s yet oddly have a bit of stretch to them
I think its the rim protector that gives the illusion of stretch, my toyo 195/45s look more stretched on my 8j wheels than my kumho 175/50s beleive it or not. The proxes have rim protector, the kumhos don't, and I'd imagine potenzas have rim protector, whereas I know federals don't as I ran federal 165/50s last year... Still, 6j attempted stretch fails, hard.
