Ignition?
hi guys,
just got a problem here, right when i turn the key to turn battery on it works dials come on radio comes etc, but when i turn that next turn to start the engine there is absolutely nothing :\ the car bump starts, but when i turn to key to turn the engine on theres nothing,
anyone shed some light on this asap please thanks :)
  • Views 1k
do the lights\dials dim when you try and start it?
If so.. maybe battery. If not, dodgy starter motor maybe?
try whacking the starter motor when turning the key solinoid might have stuck!
Its your ignition switch hotwire that bad boi sick sick yo.
Hi, I'm suffering the same issue, starts sometimes - Needs to be bumped most of the time.
Believe the starter switch is the issue - as devos coment!
Also have a pause whilst a pump kicks in all the time, its like driving a diesel! After the pump kicks in i am getting a new buzz for 15 secs relating to the problem. Any tips?
