locks not locking
I have a 1.0l polo and its a bit frustrating at the min that niether side will lock off the key, i have to lock the drivers from inside move over to the passenger side, climb out and lock it from the passenger side as it will push down. To unlock i have to climb in the boot and lean over, are they common to decide not to work? This car doesnt have central locking
thanks guys
  • Views 1k
Have a similar problem on a mk2 Ibiza, the key turns and the pin goes down, but it doesn't seem to go down far enough to actually lock the door. Is that what happens with yours?
Also be interested in a solution - I'm going to take the lock apart in a few days and have a look but if anyone can offer an easy fix that'd be much appreciated!
yeah mate one side pulls lock pin down half way but doesnt lock it but wont open the other side just spins in the lock does nothing
That is exactly what was happening on this Ibiza, both sides had the same symptoms, how strange!
For the one that spins freely, I would imagine some part of the mechanism between the barrel and door lock itself has snapped, this is a common fault, might be worth whipping the handle off first to check, but I would bet money that you'll just need one of these
http://shop.ebay.co.uk/?_from=R40&_trk...-All-Categories
As for the side that pulls the pin half way down, I haven't figured that one out yet, going to get the whole lot off the door and have a proper look when time allows
you need a lock repair kit, available from VW for about a 5er iirc.
cool will have a look at one of these repair kits thanks guys hope you get the ibiza sorted mate
