6N2 GTi Brake Setup inc Hubs
For sale is the brake setup from my 2001 polo GTI.
Calipers are both in good gondition and work fine.
Brake pipes have only done a few K so also in good condition
Carriers work perfectly.
Hubs are in good condition and bearings appear to be fine. I have sprayed they black to protect from rusting.
Pads are pretty good, they are black diamond predator.
Discs have loads of life in them have only done a few K, no lip on edge etc.
Looking for £100
Could post for cost, around £20 I think.
Located in Pontypool, S Wales
  • Views 241
These the front brakes? And will they be a direct fit to a standard model 6n2? Thanks bro (:
Ye they are the fronts and should bolt straight on!
go straight on as long as you change the hubs aswell :)
All you need to do is disconect the brake lines, ABS Connectors, track rod ends, ball joints, strut and drive shaft. Remove your existing assembly and bolt this straight on :biggrin: Shouldn't take that long either.
You have PM!
Prov Sold Awaiting Payment.
Sold!
